unknown plug
Subscribe
Feb 12, 2007
i was changing a lightbulb today and noticed this plug. it's on the same loom as the turnsignal/running light. but is taped with blue tape to the harness. fairly thick wire mabye 16-14 gauge. one pin conector with blue/red stripe.
anyone know what it's for? foglights?
BTW it's a 02 EX coupe
heres a pic of what i'm talking about
Reply 0
Feb 13, 2007
it might be side markers. ive seen kits that just plug into the harness like that.
Reply 0
Feb 13, 2007
stick a test light in it and turn the headlights on. if the test light doesnt light up, try the turn signals.
Reply 0
Feb 13, 2007
That's the wire you use if you buy the OEM foglight kit, it will plug into the wire going to the foglights.
Reply 0
Feb 13, 2007
Do all ex's come "prewired" like that?
Reply 0
Feb 13, 2007
Mine is like that. I saw it after someone ran me off the road and i hit a poll. haha
Reply 0
Feb 13, 2007
mmmmm I think you need new tires
Reply 0
Feb 13, 2007
i think mine is like that...im not sure but ill go check as soon as i can tomorrow.
Reply 0
Feb 13, 2007
sweet, so when you buy the fog light kit form honda there are no wires to run its plug and go?
Reply 0
Feb 13, 2007
Quote: mmmmm I think you need new tires
if the tire is slick then u have better tracton and better handling :P
no there just warn on the outside lip. the tires pass the "lincoln head" test in the center.
Reply 0
Feb 13, 2007
ok just did some checks.
i checked the fuse/relay locatons in the OEM instructons for foglights. nothing there. no switch plug in switch locatons. no red/wht wire on headlight switch. thus no fog wiring.
there IS NOT a conector like that on the drivers side. however there is a blue/red wire going to the horn from the same harness. same wire size. my guess is that on EDM cars your required to have a horn on each side. that might be whats it's for.
Reply 0
Feb 13, 2007
even sweeter i have been thinking about hooking up an F350 horn but i can now have 2 weenie horns instead
Reply 0
Feb 13, 2007
Quote: there IS NOT a conector like that on the drivers side. however there is a blue/red wire going to the horn from the same harness. same wire size. my guess is that on EDM cars your required to have a horn on each side. that might be whats it's for.
If you try to hook up a horn to this wire you are in for a big headache. It's for the foglights.
The other side of this plug is underneath the center console under the cupholders. You gotta look for it though. I was trying to use this when I was hooking up my fogs, but just decided to run my own wires.
Reply 0
Feb 14, 2007
+1 for you PD
Reply 0
Subscribe
