Notices
Wheels and Tires Post your wheel and tire related questions here.
OEM brake pads?? how bad are they !!!?
Old 04-23-2009
Maco's Avatar
Maco is an unknown quantity at this point
I know this is my 1st post, but i'm amazed on how bad the original factory front brake pads are. Long story short my g/f bought a new 08 Civic last May and right now she has 25k miles on the clock and the car is in need for brakes...what aftermarket set of pads do you guys suggest for this car? metalic, semi, ceramic?? The car is an 08' Civic Coupe (not SI). She tends to brake hard t times and does a lot of fwy driving. I want to buy a decent set of pads and have my mechanic put them on.
thx for your help guys.
Old 04-23-2009
Re: OEM brake pads?? how bad are they !!!?
i have a hunch that the factory pads are like "test" versions, kinda like how when you buy a printer, the ink cartridge is only half full of ink lol. on my 02 the front pads were done after 20k miles, but my next set of oem pads from the dealer lasted 40k miles. regardless, if she does alot of hard braking, i would recommend the Hawk HPS pads which are built a bit better to withstand prolonged and hard braking better than the stock semi-metallics.
Old 04-23-2009
ronaldo9's Avatar
Stock pads were not junk they just dont' last long. Plus 1 for gearbox with the Hawk HPS. I have them now and they are superb. EBC greenstuff were good too just dusty.
Old 07-14-2009
un_nica's Avatar
un_nica is an unknown quantity at this point
I am having the same EXACT experience. I have about 22K miles on my 08 Civic LX and the front pads are done. I want to purchase after market pads but here is my dilemma: I want to buy pads that match the OEM composition: (organic, semi-metalic, ceramic, etc, etc, etc). That's what I don't know. Amazingly I called the dealer's parts department and they did not know what the composition of the OEM pads were. I then called a local parts store and they said that the composition of the OEM pads were Ceramic. If this true? Thanks for your help.
Old 07-14-2009
i think newer honda still use semi-metallic. i know 01-05 did for sure.
Old 08-11-2009
Awjvail's Avatar
Awjvail is an unknown quantity at this point
From my experience, factory pads are terrible from any manufacturer.
My grandfather has an 02 Dodge Grand Caravan and he had to get new rotors and pads at 14k.
Good old Chrysler quality, eh?
Old 08-24-2009
slowboyscivic's Avatar
slowboyscivic is an unknown quantity at this point
Seems like almost all aftermarket pads squeek on a Civic. My best experience has been with the Hawk Street pads!
Old 03-26-2010
CivicArrow's Avatar
CivicArrow is an unknown quantity at this point
I have a 2009 Civic with 44,000 miles on it. We bought it used from a dealer with 24,000 miles on it in Dec. 2009. I just came from the dealer. My front brakes are squealing because the inner pads are down to the wear indicators.
The Honda mechanic said he thinks the pads are original; we live in a rural area and do no "city driving." He said that Honda pads are NOT ceramic. He said that After Market pads MIGHT -- be thinner than Honda pads and not last as long. If the material is harder (like ceramic), they MIGHT score the rotors. He recommends we use only Honda pads - for $60 a pair. He did not tell me that after market pads might squeal.
I have been told, by a VW service manager, that after market pads will squeal if used on a 2001 New Beetle. He scared me into paying VW $400 for new pads and rotors in 2003. The VW was DESIGNED to replace both front pads AND rotors each time the pads are changed. In my case, the car had 22,000 miles on it!
So, I am off to some other sights like cartalk.com to see what I can learn about after market pads. I had very good luck with after market ceramic pads on my 1995 Nissan Maxima. The pads had "heat cracks" after about 80,000 miles but they still seemed to work fine.
If I buy after market pads, I will ask for a guarantee that they won't squeal.
The saga continues ...
Old 03-26-2010
tjg312's Avatar
tjg312 is an unknown quantity at this point
of course the stealerships will try and sway you toward buying their overpriced pads, more $$ for them.
in my opinion on my 03 civic the Hawk HPS pads are great, no squeaking an great braking
Old 09-15-2010
mililani's Avatar
mililani is just really nicemililani is just really nicemililani is just really nicemililani is just really nice
Sorry about raising the dead. I was googling OEM Civic brake pads to figure out what they are made of and this post appeared. I read it and decided to add my $0.02.
I was on the original factory OEM pads on a Japan built 2001 Civic for over 110k miles (original owner). I just changed them out yesterday. Here's a pic for comparison between an old one and a new one:
http://imgur.com/SCEAr.jpg
I still probably had 50-60k miles left on the old pad before the indicator hit the rotors. Pretty amazing, eh?
Anyways, my point is your miles may vary. ;-)
Old 09-15-2010
wow and your old pads dont look that used up either!
Old 09-15-2010
lazlong's Avatar
Most late model cars have ceramic from the factory because they're supposed to be quieter but, they don't last as long.
Old 10-14-2010
kbook's Avatar
kbook has a spectacular aura aboutkbook has a spectacular aura aboutkbook has a spectacular aura about
Depends on driving styles. When I was the delivery driver. Life of break pads were around 5 months. I used to work 6 days/week and I spent at least 6 hours in the car.
Oh importantly, I used to drive in the city ( > 95%) but now I use more highways ( >90%).
The break pads last over a year now. I still preferred the oem rotors/pads. The CHEAP pads won't do the job right and the OEM pads are better than those pads. I have never tried the EBC or performance pads so I do not really know.
Old 10-14-2010
Mad Dog Tannen's Avatar
Ceramic pads handle high brake temperatures with less heat fade, provide faster recovery after the stop, and generate less dust and wear on both the pads and rotors.
And they produce a little less noise but that's not why we use them nowadays.
Please don't keep rumors going.
Old 10-14-2010
doesnt porsche use ceramic based rotors too?
Old 10-15-2010
^ Porsche uses a type of Carbon Fiber Ceramic Composite rotors.
It's actually very similar to what we use on the C17 aircraft that I maintain. Except my jet uses 8 rotors per wheel with 10 pistons.
Old 10-15-2010
04 Honda Civic's Avatar
Anyone have trouble with OEM brake pads making a clicking noise from reverse to drive? As if the pas had a little bit of play in it? I am wondering why its doing this.
Old 10-15-2010
yeah my car has clicked since it was new but only the first time you press the brake after shifting to drive. i think its just the abs calibrating or something. i know rsx does this also.
Old 08-15-2020
Jon Martinez's Avatar
Jon Martinez is an unknown quantity at this point
My wife is at 51,000 miles on our 14 accord 2.4, it all depends on how you drive. Take for instance freeway driving. If you stay in the middle lane you could get from point a to point b with minimal braking as long as you don't ride the *** of the person in front of you. If you don't keep a good distance and constantly have to brake it will wear out your brakes faster and cause worse gas mileage the two literally go hand and hand. So if your getting poor mileage then your most certainly causing premature pad wear and excessive rotor heat and warping. I would say the wear on your pads is caused by your driving, and not the pads.
TiggerDX
06-18-2015 01:43 PM
Star1967
06-08-2015 04:23 AM
rhvic
05-22-2015 03:06 PM
ayoitzjulesdx98
05-14-2015 08:29 AM
bsmiley
04-27-2015 01:27 PM
Quick Reply: OEM brake pads?? how bad are they !!!?
