Sponsored by:
Sponsored by: DashLynx
best grounding points - opinions
Old 07-21-2009
unTuned's Avatar
im about to put my grounding kit in the engine bay...its 5 pieces so it will connect to 6 points in total. any opinions on what everyone thinks the best 6 grounding points would be? whoever did the install and wrote up the diy used these 6 grounding points:
1) battery negative terminal ---> transmission
2) transmission ---> firewall
3) firewall ---> driver side strut tower
4) battery negative terminal ---> radiator support
5) radiator support ---> valve cover
unTuned is offline
Old 07-21-2009
Re: best grounding points - opinions
stock grounding points are the best.
Old 07-21-2009
unTuned's Avatar
thats what i figured so i think im going to go with the above setup, but also leave the stock ones in place. should work ok.
unTuned is offline
DVexile
07-02-2021 05:25 PM
Trav_02civic
Engine start problems
04-23-2015 08:57 AM
McD
04-22-2015 05:28 PM
WorldsSlowestEm2
11-27-2001 07:25 PM
Quick Reply: best grounding points - opinions
