Boost Problems!
Old Aug 29, 2004
ImportRacer2123's Avatar
K20 Member
Boost Problems!
OK When I was out tonight with VinylPlaya we were watching my air/fuel gauge and my RPM's. We noticed at 3500-4000 RPM range it ran lean and bogged down. As soon as I hit 5200-5400 it started to pull hard again. Anyone got any advice?
Old Aug 29, 2004
VinylPlaya04's Avatar
VinylPlaya04 will become famous soon enoughVinylPlaya04 will become famous soon enough
Anyone?
Old Aug 29, 2004
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
mine does the same tthing, but not as bad
Old Aug 29, 2004
civicskater's Avatar
Chicks dig my scent
are you using any kind of VAFC to control your fuel/timing? Was it dyno tuned? when i had my safc hooked up for 3 days before it got dyno tuned my power delivery was all over the place...down low itd be semi rich then up high it would just pull like whoa. And in between 3500-4000rpm did the boost change any at all?
Old Aug 30, 2004
K20 Member
i have a VAFC II for fuel but its at 0 Correction all the way accross because i don't know where to start. at 4500-5000 RPMS it just completely boggs if i punch it to the floor (im an auto)
Old Aug 30, 2004
Chicks dig my scent
youre probably not getting enough fuel, the only way i can think to completely solve this is get a dyno and see your A/F and how it really changes per rpm rather than just a needle, or id get a wideband, but either way it'll have to be tuned. i know you're not running the sf fuel kit, do you know what fuel/boost ratio your fuel pumps running? (mines set at 11lbs:1psi), from there you should be able to set your fuel maps on your vafc II
Old Aug 30, 2004
HyaBoosta's Avatar
yeah your gonna either need to get a wideband or get tuned. you need to set your fuel map. try playing with the vafc settings wheer it boggs down . see if it makes a diff. if it does then you know you need to get tuned.
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Danofthebass
Jun 8, 2015 08:42 PM
Mike Garvey
Jun 7, 2015 07:25 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
