MAP SENSOR QUESTION (10psi?)
Old Mar 31, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Just a quick question. Is 10psi of boost attainable w/out modification of the MAP sensor? Or will it go crazy once it sees this amount of boost?
I did a quick search but couldn't really find anything that answered that particular question. I spoke to the shop today and one of the employees said something of the like. Not sure how correct he is and the owner wasn't there so I need to see if he was in fact correct.
So .... please if anyone has any info on this let me know. Also, if the MAP sensor DOES INDEED need to bemodified...someone please tell me how?
Thanks.
Old Mar 31, 2004
andyman97's Avatar
Turbo Guru
The map shouldn't ever see any boost. If it does, it will go crazy. I've run 10 psi with one way GM check valves and had no problems bleeding off the boost.
Old Mar 31, 2004
RMSIHPA's Avatar
RMSIHPA is an unknown quantity at this point
missing links and or turbo blox will work a little better than check valves. Joe buemi the head of sales for my company was running alot of boost on his H22 swaped accord and we had 3 or 4 bleeder valves onit. it would lose to much pressure and ran like crap @ idle. we replaced the check valves with the missing link and its has run great ever since.
Later
Unstable
Old Mar 31, 2004
opto_isolator's Avatar
Maybe she is clamping the voltage electronically some how.....I know I am going to be....
Old Mar 31, 2004
C2i0v0i1C's Avatar
SuperMODrizd
synapse missing link
Old Mar 31, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Old Mar 31, 2004
RMSIHPA's Avatar
the new map sensors will hold up 10 to 11 psi before throwing a code according to my hondata rep. but i would block boost to map anyway just to be safe. or clamping would be another route.
Later
Unstable
Old Mar 31, 2004
SpdRcrChk's Avatar
BOOST JUNKY
http://www.synapseengineering.com/html/ml004.html
Thanks alot for the input guys. I'd always heard of a missing link but never really understood what it did (thanks boosted2k2). I'll prolly be looking into one of these soon as my car is back.
Old Apr 1, 2004
RMSIHPA's Avatar
glad you found it good luck.
Old Apr 1, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Old Apr 1, 2004
EnProceso's Avatar
uhhhhh....so what does it do?
Old Apr 1, 2004
Well, considering its been posted like 500 times here before (search?) - it prevents the MAP sensor from seeing boost, sort of like a check valve, but they claim it isn't (but it really is )
Old Apr 1, 2004
civicskater's Avatar
Chicks dig my scent
definately get the Missing link....but i think its worth it for $50-60 bucks depending where you get it...i ordered one just in case and i wont be running over 6psi for the first couple months
Old Apr 2, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
well i thought the MAp sensor would never know if your running boost if you doin the same set up as me
the SAFC tell the ECU that your runnin lean to increase the fuel
so it thinks that the air flow is the same as stock no matter what the MAp senor reads
the AFC just fools the ECU into supplying more fuel to accompdate the newly acquired air flow that we like to call boost.
is this right?
Tedverseti
Apr 23, 2020 01:45 PM
tmc66
Jun 9, 2015 04:07 PM
sccarally
Texas
May 17, 2015 10:11 PM
Pr0n1s
Apr 30, 2015 03:08 PM
viper775
Dec 9, 2001 10:52 PM
