Engine Swap in 1997 Civic LX
Old 02-12-2006
I Love Lamp
burnhard88's Avatar
Location: Ottawa, Ontario, Canada/ Richmond Hill, Ontario, Canada
burnhard88 is an unknown quantity at this point
Exclamation Engine Swap in 1997 Civic LX
was just wondering what would be the best way to go in swapping out the auto engine that i have now for something that's a 5 speed manual with some juice so to speak... hahahahaha... i think my engine is the D15Y7... ne opinion, tips, and advice will be appreciated
Old 02-12-2006
DONT PANIC
turboengnr's Avatar
how about a simple B16 swap? HAsport mounts, hondata ecu flash. Its a rather simple install. And 160 hp isnt bad.
Old 02-12-2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
ls turbo..
Old 02-12-2006
Chicks dig my scent
civicskater's Avatar
ls/vtec or B16
Old 02-12-2006
RHCP0801's Avatar
B16 all the way
Old 02-13-2006
I Love Lamp
burnhard88's Avatar
i e-mailed a guy at www.teknotik.com, and he recommends dropping in the
D15B engine which is the 92-95 civic si engine, 130 hp, 103 lb/ft of torque... he said that it's almost a direct drop into my car... so that might be the best bet... considering it's $700 canadian... here is the link for it... http://www.teknotik.com/product_sect...disp.php?id=56
would i need the stuff on the right hand side of the page under the optional stuff... even though it says optional, would it be a big + to have???
Old 02-13-2006
Wanna see a donkey show?
cg95660's Avatar
cg95660 is an unknown quantity at this point
LOL k20a2 would be faast.
Old 02-13-2006
EK Hatch
Ser1N's Avatar
Ser1N is an unknown quantity at this point
1997 civic has a D16Y7 stock,, Best bang would be the B18C1(GSR) or the B18C5(Type r) engine. Id say k20 but they are alot of money. B16 is a little cheaper but you dont get the nice TQ that u get from a B18.
Old 02-13-2006
DONT PANIC
turboengnr's Avatar
if you want a simple direct bolt in, go with a ZC. Theyre 130 hp, and i was able to get them for around $300 US.
Old 02-13-2006
I need TP for my bunghole
PunkingCivic's Avatar
Second that
Old 02-13-2006
I Love Lamp
burnhard88's Avatar
seriously??? even if for the conversion from auto to 5 spd???
Old 02-13-2006
DONT PANIC
turboengnr's Avatar
well, you would still have to get a tranny and what not. But early (pre 2001) D-series trannys are common as all hell. You can pick them up for $50. Then all you need is the clutch linkage, pedal, and shifter assembly.
If you go with a ZC, i seriously think you could get all the parts for less than $600
Old 02-14-2006
I Love Lamp
burnhard88's Avatar
well... i sent the list to a guy that swaps engines and says it's better if i buy a new car cuz it will cost so freak'n much... so my options are narrowed down to this... sell my civic i have now for a 92-2000 civic si manual, take my intake, exhaust, and strut bar from my car and swap it to the new one and fix it up from there... secondly, i could keep my grades high, sell my car, and get a 2003-2004 STI impreza... or thirdly, keep my grades high, sell my car, and get a 2006 rsx type-s... i'm kinda leaning towards the STI...
Old 02-14-2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
f**c the grades, buy STI right now!
Old 03-17-2006
CivicLX_Black's Avatar
CivicLX_Black should not be trustedCivicLX_Black should not be trusted
I have a seperate question but................
On a 7th gen civic would it be a good idea to put a 6th gen civic D16 engine.
Since they make a supercharger and turbo charger and all the parts are so much more common and easy to buy.
Just a thought
*******s away. Start the comments
Old 03-17-2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
It is illegal to put an older engine in a newer car, and not very wise in most cases either.
Old 03-17-2006
I Hunt Goats, Rams, And Mustangs.
TransformedBG's Avatar
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Although you could since you an addapt an older manifold to your car, you may be able to adapt a supercharger to your car, or do what i did lol. K20 SC!
Old 03-17-2006
Where is it illegal to put a older motor???
In Texas, it's OK for my 2005 as long as it's OBD-II and engine light does not come ON.
I think it would be Easy and cheap to do such a swap with a Supercharger and since the 05 LX and 1999 EX have the same HP and TQ.....I think!
There wouldn't be much difference........if so then Stoke the D17 motor before putting it in.
Old 03-17-2006
TemjinX2's Avatar
it depends on your state. In most states it illegal to put a older motor into a newer car because of emission laws.
Just a thought
Why would you want to swap out a economy engine for another economy engine. Its more worth it to save for a k-series or just get a k20a3 for cheap and turbo that.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
beneditti
01-15-2016 12:31 PM
usajags84
15
08-19-2015 03:12 AM
usajags84
05-10-2015 08:11 AM
shawe90
04-14-2015 07:10 PM
Quick Reply: Engine Swap in 1997 Civic LX
