DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
#61
1 Post
Originally Posted by k20newbie
taking off subframe civic.But is it need to get subframe from dc5 put in side?
i only bought the engine and other stuff but no sub frame d5.
e mail me Dannziggg@yahoo.com
subframe from either and rsx or 02+civic si
lol... could i been any more rude... haha
Last edited by xproductionz; 03-09-2006 at 04:28 PM. Reason: Automerged Doublepost
#62
1 Post
Rep Power: 273 i forgot the most important thing that i forgot to add to the list of things your going to need for the swap if it didnt come with one already
you are going to need the CLUTCH SLAVE CYLINDER which attaches to the tranny that pushes the clutch padal on the tranny in and out for the clutch to engage. i remember when i was doing the swap and i thought i had everything... but that was the one thing that was missing that wasnt on the parts list that hasport has..
#63
1 Post
Rep Power: 273 hmm.. i was just wondering.. if i offered services of wiring up your stock harness for the swap... basically you send in yours then i weire it up and send it back to you... wondering how much would people would be interested..????
another thing.. here is my interview of me on street fury and my 7thgen with the swap
http://xproductionz.com/uploads/stre...-loquality.wmv
http://xproductionz.com/uploads/stre...-hiquality.wmv
#70
Rep Power: 233 Yah I really wanna get a k swap, but I have no idea what I should get. Im lookin to get 350-400whp when Im done, so its gunna have to be turbo. whats best for that? a k24 block and a k20a3 head?
#73
1 Post
Rep Power: 273 u know what.. i just noticed i never really posted any pics of my setup in my car.. lol.. well.. better late then never..
http://www.7thgencivic.com/forums/sh...d.php?t=263665
#75
Rep Power: 0 When swapping a k24a1 frank into a em2, what half shaft should I use with the ep3 axles I already have? Seems like I read somewhere that the k24 and k20 half shafts are different. Also, should I use the crv o2 sensor?
#76
Rep Power: 0 k20a2 5spd?
so i want to do the k20a2 in my 01 civic ex coupe and make the type-R the way it should have been in a civic coupe body cept i also am hoping for between 300-350 hp all motor but what im worried about is i hear the stock type-s brakes its tires loose in the first two gears so i was thinking i could use the 5 spd instead so my second gear is taller and it will alsot help me keep an illusion of stock which i would like to do as long as posible so basicly im asking does any one know if its been done and if it could stand up to that much power
thanks
thanks
#82
1 Post
Rep Power: 273 lol.. forgot about that... haha..
anyways everything else is simple and stright forward..
remove old subframe
bolt up new one
lower motor in and bolt up to the mounts...
if anything though i will go into more depth about it simetime this weekend
remove old subframe
bolt up new one
#84
1 Post
Rep Power: 273 powersteering no... a/c.. uhh.. it kkinda depends on how you route it.. thers 3 different ways... you can use the EP3 ac lines... rsx lines (this is what i am using) and/or get custom lines made
#87
Rep Power: 0 I read somewhere the clutch line needed for the swap would not work with the civic master cylinder? Do I need a rsx clutch master cylinder? I already have the slave with hardline attatched.
#88
1 Post
Rep Power: 273 im still using the civic master cylinder. i havent changed anything and i am sure everyone else that has done it still uses the original master cylinder. the only thing you need is the clutch lines from master to slave.. nothing more.
#89
can u send me the pics of your swap as you go, because we can't see it and i'm doing one myself...tanx
while i'm here i have a problem with a swap that i just did...d17 non-vtec to a d17 vtec with all herness included and ecu (keys had to be reprogrammed)...the problem is that i have a vtech malfunction, cutoff at 4000 rpm.?????on all the gears...even the dealer doesn't know what is it! can you help me with this...and i think that there is a heater malfunction when they did the ecu scan......is really anoying (excuse my french...i'm from montreal canada)
