Car shakes at highway speeds
Rep Power: 222 Car shakes at highway speeds
hey guys, need your input...
last wednesday i noticed that when i would go 60mph or faster, my car would start to shake, nothing violent, but a vibration i could feel through the steering wheel. i figured my wheels just needed to be balanced, so i had the front two balanced today...
the shaking is still there however and im a little annoyed... anyone have the same thing happen?
solutions?
thx
solutions?
thx
Rep Power: 233 Re: Car shakes at highway speeds
Should've gotten an alignment while you were there. Also get your tires checked out. One of my tires was damaged and had a big lump on it, causing the car the vibrate at high speeds.
Rep Power: 788 Re: Car shakes at highway speeds
could be....
-improperly balanced wheels
-uneven tire wear
-torn front bushings
-other suspension damage
make sure you take them to a shop that knows how to balance. usually thats the problem. does the vibration sometimes go away, or is it constant? could also be the tires, if the wear spots are different. can try swapping the front and rear tires and see if that helps.
-uneven tire wear
solutions?
thx
solutions?
thx
With CV joint wear the longer of the two front axles can get out of balance as it becomes offset in the worn bearings and does once-around vibration only at specific speeds. (The shorter axle is far less affected by CV bearing wear. )
Look at the boots covering your CV joints (front axle Universal joints) to see if there's any damage and sign of ingress of water that can dry out the lubrication and promote wear.
Last edited by BustedSony; 02-20-2008 at 12:46 AM. Reason: added comment on tire balance.
Rep Power: 0 Re: Car shakes at highway speeds
Not sure what kind of rims you have, but i had a similar problem with mine. Took the wheel off and noticed the inside of it was bent. Replaced the wheel and it fixed it.
Rep Power: 222 Re: Car shakes at highway speeds
kk, so my mech put the car up on stands and we realized that the belt on the rear drivers side tire has snapped... dunno how that happend but come monday ill have everything fixed
thanks all
thanks all
Rep Power: 220 Re: Car shakes at highway speeds
Ok...can't help but post this...This is by far my favorite site to visit but at the same time please get a feel for your car mechanically. Maybe I'm 'racist' for the fact that I'm a mechanical engineer that has a feel for real life (if you ever have to deal with engineers you'll understand) but please feel/listen harder and try to use your gut feel to pin point problems before posting or going to your mechanics. I mean this for anyone reading this; if you don't have that feeling your getting ripped off (please don't get ripped off you drive a civic too).
I feel the same as the last poster..one of the things that always starts to happen is after you get something done to your ride...look it over really good to see what other damage they might have done...even like dropping your car off of there jack stands can bend a rim ...
WheelBrokerAng
WheelBrokerAng
You Stay Classy, San Diego
ok this is gonna sound really dumb but it happened to me. I took off my summer wheels and put my steelies back on for winter. After that my wheel was shakin like mad. Took it into the stealership for a service and asked them to find out the problem. It turns out my summer wheels have these rubber gasket type things that go on the inside of the rim. The gaskets stuck to the brake disks in the front and wen i put the steelies on they weren't fitting properly. kinda scary when you think about it. but its fine now
The World Is Yours!
Rep Power: 301 Re: Car shakes at highway speeds
take the car to a shop and see if the use Hunter balancers.. then check if they have a road force machine... have them checked...WATCH them... and see if the tires are high road force or separated... if not rebalnce nad check for bends or warped wheels!
Rep Power: 225 Re: Car shakes at highway speeds
i have a really dumb story about those. i was putting my steelies back on and it was super cold and dark in my driveway so i was in a hurry, didn't take off the plastic hub rings, heard cracking when i tightened the wheel down then a piece of plastic flew off, bounced off something and hit me in the face. won't do that again.
dragonsblood
04-27-2015 12:28 PM
GH04si
04-15-2015 08:13 PM
dooner24
04-14-2015 07:51 PM
