Steering problem...
Old May 18, 2006
goodtimes's Avatar
Steering problem...
hey i had a question
when i make a hard left or right turn(suspension is under compression) after the turn my steering wheel stays off center to the way i turned. Say i turned and made a hard left the steering wheel would stay to the left a little, do you guys get what im saying?
could someone help
im on megan coilovers
thanks.
Matt C
Old May 18, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
You mean steering wheel not returnig to center position?
I'd think strut bearings might be responcible for this.
Old May 18, 2006
goodtimes's Avatar
When i turn the wheel to the right hard then im coming out of a turn the wheel goes back good but its off centerd like maybe 5-10 degrees, when i get to a stop light and sanp the steering wheel the other way the steering wheel be comes center agen.
andd i hear a poping noise.
Old May 18, 2006
CASPER087's Avatar
People point and laugh when I drive by. Plus I like men.
CASPER087 is an unknown quantity at this point
mine did that and i fixed it. just im me on aim at caspero87 and ill tell you what to do so i can get in more detail with you.
Old May 19, 2006
goodtimes's Avatar
anyone have anymore input
Old May 22, 2006
goodtimes's Avatar
bump???
Old May 22, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
Check Ur Alignment
Old May 22, 2006
Zzyzx's Avatar
Autocross Junky
Originally Posted by goodtimes
bump???
are you on or off the throttle when this happens?
Old May 22, 2006
goodtimes's Avatar
im kinda on it, but not hard just like 30%
Old May 23, 2006
Zzyzx's Avatar
Autocross Junky
are you experiancing any wheel spin? any understeer? or just an increase in steering effort.
Old May 23, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
If its not recentering, i'd be looking at the rack. It sounds like its out of adjustment in some way and the pinion isn't coming all the way back to center. Either its jumping a tooth on the rack if/when it hits the lock, or there's too much slack in the yoke adjustment.
Do you have a very floating feeling on center?
Also check the tie rod end connections to the strut and the tie rods, as well as the lock collars on the struts. If anything is loose, your wheels may not always point where the steering wheel is.
Old May 23, 2006
goodtimes's Avatar
could it be the camber bolts... everything seems tight i just got new tie rods end not to long ago. by a floating feeling you mean i turn the wheel slightly to ither side it the car does not want to do anything just keeps on going in a strat line? then yes
Old May 23, 2006
Zzyzx's Avatar
Autocross Junky
Curious, did you get an alignment after installing the coilovers?
Old May 23, 2006
TeLLy's Avatar
Yes, it's an Acura EL
I got this noise just this last weekend. I'd been driving on a super-bumpy highway and the vibration worked my front driver's perch locks loose - the lowest one that sets the height. Once I tightened it then tapped the wrench with a hammer to really tighten it up, no more noise. I had a similar problem with my Hayames way the fuqq back. Can't say anything about ths steering though, mine feels OK to me.
Old May 23, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
get an alignment
Old May 23, 2006
goodtimes's Avatar
yea i did get an alignment after i got the coilovers on, im get one soon b/c i just replaced my camber bolt with stock 16mm oem bolt, dident need two camber adjustments since i have camber plates.
Old May 24, 2006
invrtdsa1nt's Avatar
invrtdsa1nt has a little shameless behaviour in the past
have you hit a curb? i have the same exact thing going on and i hit a curb hard. i personally think its the steering rack.
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
