2011 CR-Z wheels on a 2002 Civic LX
Rep Power: 0 2011 CR-Z wheels on a 2002 Civic LX
I have a spare set of 2011 CR-Z wheels I bought because mine came with some curb rash when I bought the car. If I were to put these on the '02 Civic LX, I believe I would need a 4x100 to 5x114.3 wheel adapter if I'm correct. Is there a certain thickness that would be best to keep it around stock wheel placement? The offset on the CR-Z rims 45mm. Specs for the rims are as follows:
Standard on all CR-Z models (Base, EX, EX w/ Nav):
Wheel size: 16×6 Alloys
Tire size: P195/55/16 86V
Bolt Pattern: 114.3/5
Offset: 45
Hub Diameter: 64
The Civic appears to have a 56.1 hub and the CR-Z is a 64. Is this even possible to swap with adapters? May not be. Might be going down an impossible road. Just curious since they're sitting in the corner of the living room.
Offset: 45
Hub Diameter: 64
Prelude Owner
Re: 2011 CR-Z wheels on a 2002 Civic LX
Your going to need hub adapters and by pattern adapters. You may be able to find adapters that do both.
You want as small a spacer as you can unless you want the wheel to stick out more.
It is generally not suggested to use lug pattern adapters.
Rep Power: 0 Re: 2011 CR-Z wheels on a 2002 Civic LX
Well from looking around for these spacers / adapters a little bit, it seems they are about 2" thick. Probably not the best way to do that. I think that is mainly to miss the lugs for the adapter when mounting the wheels. Seems like an impossibility.
CarStuff
12-06-2020 12:52 PM
CapYoda
11-11-2001 05:17 PM
