Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-06-2002   #1 (permalink)
Taffy
Random Person
Taffy's Avatar
Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future Taffy has a brilliant future
Check Engine Light/Gas Cap
My Check Enigine came on while I was driving last night and I was freaking out. Someone told me to check the gas cap and when I did, I figured it was the cause of the light coming on because I did not close it tightly.
How long does it take for the light to go off after I tightened it back up?
Taffy is offline   Reply With Quote
Sponsored Links
Old 11-07-2002   #2 (permalink)
CarbonFly
CarbonFly's Avatar
CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all
Send a message via ICQ to CarbonFly Send a message via AIM to CarbonFly Send a message via MSN to CarbonFly Send a message via Yahoo to CarbonFly
You have to tighten down the cap until it clicks 3 times.
CarbonFly is offline   Reply With Quote
Old 11-07-2002   #3 (permalink)
BrotherSound
Super Member
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
Send a message via AIM to BrotherSound
i would think after you tightend it with 3 clicks it should go off? if not thats weird
BrotherSound is offline   Reply With Quote
Old 11-08-2002   #4 (permalink)
2Hottie
Member
2Hottie is an unknown quantity at this point
Send a message via AIM to 2Hottie
Quote:
Quote
[hr]Originally posted by: BrotherSound
i would think after you tightend it with 3 clicks it should go off? if not thats weird[hr]
3 clicks is the trick! If you didn't do the 3 clicks, be prepared to make a trip to your local Honda dealer to get the light reset....the only way I was told it can be done...
2Hottie
2Hottie is offline   Reply With Quote
Old 01-04-2003   #5 (permalink)
Steveo
Member
Steveo is an unknown quantity at this point
Send a message via AIM to Steveo
Just open the hood, and take out the 7.5 amp memory fuse, and wait 10seconds, then put it back in....problem solved dude!
Steveo
Steveo is offline   Reply With Quote
Old 01-29-2003   #6 (permalink)
LOXLEY
Member
LOXLEY is an unknown quantity at this point
the check engine light is programmed to come on. read the manual it will explain this and how to get rid of the light. but the manual left out one tiny detail. make sure your odometer reading is showing and not your A and B trip setting before you go through the motions to reset the light.
LOXLEY is offline   Reply With Quote
Old 02-21-2003   #7 (permalink)
noahnoah
Senior Member
noahnoah's Avatar
noahnoah is an unknown quantity at this point
Quote:
Quote
[hr]Originally posted by: LOXLEY
the check engine light is programmed to come on. read the manual it will explain this and how to get rid of the light. but the manual left out one tiny detail. make sure your odometer reading is showing and not your A and B trip setting before you go through the motions to reset the light.[hr]
I think you're talking about the maintenance required light, not the CHECK ENGINE light. The manual doesn't say how to reset the CHECK ENGINE light. If it does I don't know where.
noahnoah is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
