Clutch engagement iissues
Rep Power: 0 Clutch engagement iissues
Lately ive been experiencing some weird cltuch pedal issues with my 7thgen. To note, I know the input shaft bearing is pretty bad and requires replacement.
The issue is, ill start my car in the morning and when i press the clutch pedal in its a little soft. Maybe an 1.5" of free play, but still able to shift no problem. Then after a half hour of city driving, im noticing that my pedal is becoming more firm to the point were the free play is all gone .
I had a full car full, going up hill and the clutch started to slip as if it was slightly depressed( The clutch and pressure plate have under 10K since install)
I adjusted the clutch pedal after that day, and it hasnt gone to the point of slipping again but does get very firm.
You let the car cool down overnight and its soft with some free play.
Ive checked the fluid, and im not loosing any. I thought maybe air in the system but its also been 5000k since installing a mastercylinder and bleeding.
Im not a transmission expert by any means, im wondering the the bad input shaft bearing could some how allow the shaft itself to move slighty causing the clutch itself to be shifted more towards the flywheel?
Im going to try to bleed the system again tomorrow using a vacuum bleeder
Any input is greatly appreciated
Re: Clutch engagement iissues
I'd check free play in the pedal pushrod adjustment. Insufficient free play could cause it to do what you described.
Check for contaminated fluid, make sure nobody dumped in oil or something.
sesi
10-01-2015 02:03 PM
ThatGuy913
09-28-2015 05:35 PM
powman02
09-15-2015 07:38 PM
Klame9420
09-07-2015 10:03 PM
