04 Civic Coupe Hood Release Knob Broken off
Rep Power: 0 04 Civic Coupe Hood Release **** Broken off
I understand that the hood release **** breaking off is a fairly common problem. Mine broke off. Any ideas on how to fix it without having to disassemble half of the car replacing the entire cable? Thanks guys.
Re: 04 Civic Coupe Hood Release **** Broken off
The plastic handle breaks off rather often......maybe because the cable needed replaced?
Fix for the lazy:
Fix for the lazy:
Rep Power: 0 Re: 04 Civic Coupe Hood Release **** Broken off
Its for sure the **** end of the cable that broke off. You can grip the stub IF you can get a hold of it and open the hood. The vise grip idea is a good one. Also saw a YouTube where a guy took like a 3/16 drill stop sleeve with a set screw in the side of it and put it on the end of the stub and walla. Ordered a set of drill stops on eBay and will see if that does the trick.
CapYoda
11-11-2001 05:17 PM
