i need help bad
Rep Power: 0 i need help bad
01 civic dx when i go over bumps i get a clunk from right rear? no sway bar what would be clunking over bumps? i can push down on trunk and make clunk happen but its not as loud?
Prelude Owner
Re: i need help bad
Possibly the rear lower strut mount bushing. Jack the back of the car and inspect the rear strut assembly. Also make sure the top hats are tight, bolts are located in the trunk.
No amateur/no professional
Rep Power: 0 Re: i need help bad
I'd recommend buying a $2 stethoscope from Harbor Freight ($10 at Autozone) and getting a buddy to replicate the sound while you are under there and can pinpoint what it is. If it is too low or tight then back up your car onto some plywood or something sturdy so you can get under there. I've found almost all my suspension issues this way. Why guess? Find the exact issue and save time...
Green02civic
07-27-2015 10:48 PM
CivicsClass101
07-09-2015 11:14 AM
