A/C belt squealing
Rep Power: 0 A/C belt squealing
Obviously this is due to lack of tension on the belt. Is this the same belt that goes through the alternator?
I'm trying to find out what bolt I need to tighten up to get rid of the squeal. Is it the wing nut on the alternator?
Rep Power: 210 Re: A/C belt squealing
Same belt. No wingnut on the alt. From top to bottom- P steering, alt, A/C compressor.
To adjust: Loosen B, C, and D. Twist the wingnut (E) to adjust. Easiest way I've found to reach is to take off front driver's side wheel.
alxz310
07-30-2015 12:18 PM
1khilari
07-09-2015 08:12 PM
