detailing help needed
Old 12-19-2014
chgofirefighter's Avatar
chgofirefighter is an unknown quantity at this point
I just purchased a buffer, but quite honestly I have never detailed a car to the point of needing one. I just purchased a pre owned Honda Civic LX, which needs a detail especially with the paint. I washed it and cleaned it to the best of my ability, however you can tell that the paint has some rough film over the paint, like the car was sitting outside for a very, very long time. I would like to use some rubbing compound, etc but honestly speaking I don't know what materials I need to get this job done the right way. I have never needed to use a buffer before because all of my previous vehicles are garaged kept and always washed and waxed but this car is another different story...
So can anyone direct me as to what I need to buy and how I can proceed with this project? Thank you in advance~
Old 01-05-2015
cardetailer18's Avatar
cardetailer18 is an unknown quantity at this point
Re: detailing help needed
Hi there, can you post some pictures of the paint? Your paint may have clear coat failure in which case buffing is not going to fix the issue.
Old 01-29-2015
marteam's Avatar
marteam is an unknown quantity at this point
The Optimum poliseal is a good product. It polishes the surface, can remove light scratches and seals the paint.
Old 02-18-2015
ZeroTo100's Avatar
ZeroTo100 is an unknown quantity at this point
Sounds to be like your clear coat (the actual "shine" to your paint) has faded due to oxidization / the sun beating on its *** for years... You need to re-clear coat the panel or the entire car... Doesnt neccessarily mean you have to paint the entire car. Clear coat and paint are 2 diff things. I dont think buffing will help. But, try 3 step or 2 step waxes. Such as G6 cutting compound, then couple it with some sort of carinoba (sp?) wax / any waxing product really.
Old 02-12-2017
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
Pics are needed to see the extent of the paint fade ...?
this is a timely 3 step process so be patient if You want results.
if its just faded paint You can use Maguires Ultra compound
does a great job at revivng the paint back You might need to re-apply
it twice buff let dry to haze wipe off. apply let dry wipe off
for optimal results. then apply maguires ultimate Polish this will
bring back more of the coloure that was lost in the paint back out
again let it dry to a haze wipe off. then use maguires ultimate Wax
this Wax is the final step at sealing in all the work you did and protecting it and that's it.
Old 02-12-2017
brags's Avatar
link to maguires ultra compound below this will be your 1st step
GolNat
09-10-2015 08:25 PM
ImmortalEX
Detailing
78
09-04-2015 05:35 PM
hokiedad4
04-30-2015 07:18 AM
Myredjonda
04-14-2015 07:00 PM
SneakerPimp
11-28-2001 10:45 PM
Quick Reply: detailing help needed
