Squeaking in clutch pedal
I have a 05 civic ex coupe 5 speed, completely stock. Started noticing a squeaking like noise in the clutch pedal everytime I push it in and let it out. I can feel it in the pedal also. Is that bad? Fixable? its kind of annoying. can anyone help me out or give me any suggestions?
Prelude Owner
Re: Squeaking in clutch pedal
Welcome to the forum.
It's the tension spring on the clutch pedal that is making the noise.
Get a can of Teflon or white lithium grease and spray the spring. Work the pedal while you spray it, the noise should go away.
Received 1,156 Likes
Rep Power: 485 Re: Squeaking in clutch pedal
Wasn't the clutch squeak from the slave cylinder push rod?
https://www.civicforums.com/forums/1...ml#post4556269
Rep Power: 131 Re: Squeaking in clutch pedal
hey golnat I have this same problem only when I push in my clutch it makes s squeak noise.. its really annoying im going to try your solution today though! ill update ya thanks! also the guy I got car from said it was stage 2 clutch// anyway to verify that?!?! thanks~
No. It's not the stage 2 clutch. Squeaky clutch is a common thing in 7thgens
Forgot to comment back on the thread. I ended up laying in the floor board and pushing the clutch half in and spraying some white lithium chain lube into the cylinder and that quieted it down quite a bit.
I have heard it squeak from the front of the engine (even after I packed the push rod with grease) but that's usually just when I pull up to the drive through or something.
The squeak coming from inside the car was way more annoying!!
Scout1
10-05-2015 01:33 PM
Klame9420
09-07-2015 10:03 PM
violentpanda
09-07-2015 11:49 AM
tommycanada
09-05-2015 04:59 PM
