10th Generation Civic 2016-2021 Discussion for the 2016 to 2021 Honda Civics.
Chassis codes: FC1, FC2, FC3, FC4, FK4, FK7, FK8
Numerous Engine Lights are ON
Old 07-20-2016
Jay Lock's Avatar
Jay Lock is an unknown quantity at this point
Hello,
I have a 2012 Civic that now has numerous indicator lights that are on below is the list.
Check Brake System
Check TPSM System
Check emission system
Check Air bag system
Check power steering system
Check ABS
Check VSA system
Drove the car to work no issues. Get into the car and start it up and all of the indicator lights are on. Car does not run smooth and I attempted to scan for codes with a OBII meter and it is not communicating with the main computer.
Has anyone else had this issue?
Thanks,
Jay Lock is offline
Old 07-20-2016
Re: Numerous Engine Lights are ON
What you see is typical. A single check engine light code can cause many other systems to set related fault codes as many interlinked systems rely on info obtained from the engine computer. Same can go for ABS related issues, a single fault code can turn on several other warnings.
Did your code reader ever work on this particular car? Try a different reader?
(Your average OBD2 code readers won't be able to touch all of the other systems on the car)
Also.....Rodents love to eat wiring and tubing.
ezone is offline
Old 08-04-2016
Jay Lock's Avatar
No. I took the car to a local shop that repairs imports and he stated that none of his readers can read the ECU. It appears that the ECU stopped working.
I am considering removing and replacing the ECU, ignition switch and keys. Are there any other components that will need to be replaced. I had this same issue with my older BMW several years ago and replaced the same items and it worked out well.
Jay Lock is offline
Old 08-04-2016
It's a PCM, and if it can still run the engine then it hasn't quit working completely.
You apparently have a communication problem, a network problem, or a reader/scanner that's too old to read these newer cars.
These aren't like the older cars. It's just not that simple.
You'll be money ahead to take it to a Honda dealership (hopefully with at least one really smart tech who can actually diagnose) before throwing fistfulls of money at something you have zero access to electronically, and zero information on fixing.
Where are you located? Maybe I have a contact who can help.
ezone is offline
Old 08-04-2016
Jay Lock's Avatar
Wilmington, North Carolina.
Jay Lock is offline
Old 08-04-2016
I'll have to look later when I have more free time.
Also, if it does turn out to be a genuine PCM problem, it's covered by warranty for 8 years/80,000 miles. Check your warranty info booklet in the glovebox.
I doubt it will be that though, these things have been pretty reliable in my area.
ezone is offline
Old 08-04-2016
Jay Lock's Avatar
It starts up and runs, but runs rough. Actually runs good once it reaches a speed of 35+.
Jay Lock is offline
Old 08-04-2016
Nobody found in my Rolodex from either Honda dealer right now. Sorry.
Did you try Autozone or similar parts stores for reading codes for free?
If your local independent shop doesn't have the scanner equipment to handle it, just take it to your dealership.
You KNOW they have the correct equipment to handle it.
Open the hood and look for rodent chewed wiring on the injectors and coils?
ezone is offline
mgcivicdriver
Engine start problems
16
12-10-2015 11:58 PM
Stussey21
11-02-2015 11:03 PM
Garagenut
10-22-2015 10:34 PM
R Steele
10-22-2015 05:09 AM
nymbus2k
11-11-2001 08:53 PM
Quick Reply: Numerous Engine Lights are ON
