Turbo help on a 95' dx sedan
I am looking to install a turbo into my 95 dx sedan, but I'm not sure which turbo to get. I am looking to go cheap, and do around 5 psi. Will the engine be able to take the added power? If so, which turbo (for cheap) would you guys recommend to me?
Received 1,450 Likes
Rep Power: 339 Re: Turbo help on a 95' dx sedan
no cheap turbos keeps cheap for long. must pay for good engine management to avoid catastrophic engine failure.
get $500 emusa ebay turbo kit, wideband gauge/sensor, adjustable 4:1-12:1 FMU, a few check valves from home depot for MAP sensor line, and a walbro 255 pump.
-Install check valves to allow vacuum flow to the map sensor but not boost
-Install fuel pump in tank
-Install turbo kit with 5-6psi gate setting
-Start FMU at 12:1 (rich) and adjust down until 11.5AFR at WOT on wideband gauge.
Flog it hard until you get too greedy and up the boost and blow it up.
Biggunschad
09-11-2015 04:06 PM
h4ldol
09-10-2015 12:25 PM
Ultra Havoc
09-09-2015 10:58 PM
