Dimmer switch?
Old Oct 22, 2008
Booncha57's Avatar
Booncha57 can only hope to improve
Dimmer switch?
I just got a '94 Civic lx from a friend and I remember that his dash lights would randomly go off. He would slam the dash and they'd come back (loose connection I guess). Anyway, now I have the car and the lights don't work at all (all that slamming I'm sure). Is there a switch I can replace or do I need a whole new cluster? I make sure it's not a fuse, but I think since it was an intermittent problem, I don't that that's it. Let me know!
Old Oct 22, 2008
Booncha57's Avatar
Re: Dimmer switch?
I'll add that it's all of the gauges and climate controls that don't work. The clock and the little green lights on the climate controls that indicate which one you are using still work.
Old Oct 24, 2008
RallyeRedRider's Avatar
RallyeRedRider has a little shameless behaviour in the past
Re: Dimmer switch?
You need to use a test light and start at it. I'd start with all the grounds. Just keep testing different sections until you figure out where the break is.
Old Oct 24, 2008
CraigW's Avatar
Re: Dimmer switch?
Search the web for the free factory service manuals available.
You need a schematic and some help with wire colors.
Are your tail, licence and front parking lights working ?? The dash illumination works off of the marker/tail circuit.
robjcivic
Mar 12, 2017 12:10 PM
MamaBear2015
49
Sep 29, 2015 01:12 PM
junkyardguy
Sep 2, 2015 06:07 PM
dtdoyle
25
Aug 30, 2015 06:57 PM
robbie374
Jul 7, 2015 02:56 AM
