Defroster wire detached from window.
Old 02-02-2017
Sionolann3's Avatar
Sionolann3 is an unknown quantity at this point
Tried soldering the piece that connects to the window heat element with no luck. Has anyone been able to do it with normal solder? I was thinking about getting a silver epoxy kit or something.
I have a 1996 LX. Defrost would be nice with winter and all.
Old 02-02-2017
Re: Defroster wire detached from window.
Ask at your local parts stores....Someone makes a small kit designed to reattach the tab to the glass but i personally have not used it.
Found a video with a silver epoxy product in it:
https://www.youtube.com/watch?v=reFNQlkIJ6w
Back in the 80s-90s, Mazda offered a repair terminal for this problem on.....RX7 hatchback glass among others, the terminal came pre-loaded with solder and I believe the solder used was some that would melt at a super low temperature. Not sure if that is still available these days.
Old 02-03-2017
CraigW's Avatar
Use caution on that tempered glass and heat.
Ezone... You need a Wankel with all that redline driving you do daily.
Old 02-03-2017
mikey1's Avatar
agreed,
especially if its cold outside....
Old 02-03-2017
Sionolann3's Avatar
I'll make sure to wait til it's below zero and then I'll use a soldering iron and a hammer to get rid of the old solder before I sand it.
Thanks guys.
