Civic EX 2000 Acceleration Issues
Rep Power: 0 Civic EX 2000 Acceleration Issues
So I'm definitely a noob here. I'm still learning a lot about cars so I have a waaaaays to go to knowing the lingo and all.
Recently I've been noticing problems with my acceleration, especially on hills but also on flats. It feels like I have to really kick down on the gas to get it moving and even then it feels like it's thinking about it or even somewhat like the parking brake is on. Simply feels like there's a lost connection between my gas pedal being pushed and the wheels moving.
I took it to my local garage and they couldn't replicate the issue because it's not consistent but I really wanna try to figure this out before it becomes a bigger issue.
Any thoughts?
Any thoughts?
Re: Civic EX 2000 Acceleration Issues
Here's a few inexpensive things you can do that may help. I am sure you can find DIY's or videos on line to show you how for each one.
1) check air filter = if dirty replace
2) remove and clean the throttle body or at minimum spray it out with throttle body spray (a.k.a carb & choke cleaner).
3) check tension in throttle cable
4) if yours is an automatic transmission maybe it is slipping ..if so start with an ATF (automatic transmission fluid) drain and fill.
Any codes?check electrical connections of ignition coils and fuel ingectors
Any thoughts?
Any thoughts?
Rep Power: 0 Re: Civic EX 2000 Acceleration Issues
I have an automatic
As far as codes go, how do I find out the codes? I wouldn't even know where to start with ignition coils and such...
rcolosi
04-29-2015 07:48 PM
civic_gt
04-19-2015 08:15 AM
dooner24
04-14-2015 07:51 PM
