rpms surging
Rep Power: 0 rpms surging
I have a 97 civic HX with a surging problem. I bought the car about a year and a half ago and it still has the problem but here are the issues
Problems:
Car turns off randomly
Rpms surge when car is warm
Also surges after I run the car at around 40 mph and then slow down to around 20mph
Lights dim when I accelerate
If I break the Rpms rev up to 2k
When car is warm and comes to a complete stop, car struggles to stay on
There's a few more that I can't think of...
Things I've done:
I got a new battery
Alternator checked and is good
Cleaned the tb
Cleaned the intake manifold
Changed both tb and intake manifold to skunk2 problem was still their so switched back to stock
Things I have:
I have a small sound system
And a viper alarm
I have a feeling it's the eld I'm not sure
Any suggestions on what I should or if any one knows how to fix it that would be great
Thank
Oh I also have 3 cel I'll post them up late
Problems:
Things I've done:
I got a new battery
Cleaned the tb
Things I have:
And a viper alarm
Thank
Rep Power: 176 Re: rpms surging
thats is your idle air control valve thats causing the surge,
take out the intake air box tube look at your throttle bodie door valve
before it on the inside wall, there should be a small hole where air is suck in
do this when the car is at temp , carefully use your finger or to block that hole and watch the car run normal, and if so just replace the idle air control valve
bolt-on-bandito
Electrical
32
01-15-2020 03:25 PM
Bruce2
09-27-2015 08:45 PM
NROD315
09-23-2015 03:46 PM
Juanb24
09-15-2015 12:39 AM
thaler4cuse
09-07-2015 08:25 PM
