What do I need to install a headunit?
Old Jun 22, 2003
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
Just bought a headunit off ebay and it didn't come with any instructions or anything, just the faceplate itself and a remote.
Anyways, do I need any tools or kits to install the headunit or is it pretty straight forward like the DIY?
Thanks
01SOHCcivic
Old Jun 22, 2003
darklegacy540's Avatar
darklegacy540 is on a distinguished road
You need a dash kit so the new head unit will fit the opening where the factory deck was. They come in two different types. You can get just a regular one where it just fits in the top half or you can get one that fills the whole thing where you can get rid of that drawer that the car came with. The one that replaces the drawer looks a lot better IMO..
You'll also need a wiring harness, some heat shrink, some solder, and some electrical tape. OR you can get the cool liquid electrical tape.. then you dont need the heat shrink. No clue on how much it costs though... anyways, have fun, don't short anything out lol
Old Jun 22, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
assorted screw/nut drivers, wiring harness, dash kit, i reccommend soldering the wires, if this is not an option, or if you are uncomfortable doing this, or unsure on how to, you can always use closed end crimp on connectors, the screw on connectors, butt connectors, or really any wire connector you choose... its pretty much straight forward as the DIY states, its a fairly simple install...
Old Jun 23, 2003
Dimplebutt's Avatar
Dimplebutt is an unknown quantity at this point
i got a dash kit if you're interested it's hte metra kit that replaces the drawer.
Old Jun 23, 2003
ga4dr's Avatar
ga4dr is an unknown quantity at this point
whats up guys i work at circuit city you need to remove the plastic piece under the radio where the cigarette lighter plug is there is two 8mm bolts undo them pull the radio out i think thats it youll need a metra dash kit model met 997899 wiring harness model number met 801721 use the metra dash kit its the best
Old Mar 3, 2012
paulymcd7's Avatar
paulymcd7 is an unknown quantity at this point
Re: What do I need to install a headunit?
to avoid shorting anything its advised you disconnect your battery also make sure that if you sell your stock radio you know the 5 digit code otherwise they cant use it and seeing it wont be in the car s dealer probably wont give them the code under suspicion of theft
Old Mar 3, 2012
sl33pyriceboi's Avatar
You are replying to a 9 year old thread that's dead dude
Old Mar 5, 2012
PacosTacos88's Avatar
PacosTacos88 is an unknown quantity at this point
I think we have a record here...
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
