amp and speaker hook up
alright i am gonna hook up some amps in my car soon. for the regular speakers not subs . i am hooking up pionner 200 watt amps to every pair of speakers and i was wonder what u guys thought was the best why to do this. run all new rcas from my aftermarket headunit? or should i use the high level inputs? or should i do it in another way. i really have no idea what to do right now beacuse i have 4 pairs of speakers i needa hook up so what if i took 2 lines of rcas to the back and then split it with spliters and hook that up to the corresponding amp?
need ideas guys i have no idea what i should do/what would be the best
thanks guys
thanks guys
The Standard One
i think best way would be to use 2 pairs of RCAs. that way you have the ability to fade. if you use 1 with splitters then you wont be able to.
why use high level inputs when you have RCAs that give you a better signal.
You need to hook up 4 pairs of speakers? As in a total of eight speakers? Where are you puttting all of these speakers?
If you are referring to component speakers, being a woofer and a tweeter, 4 times, doesn't it have a crossover that takes one set of speaker wire from the amp and directs frequencies to both a woofer and a tweeter? In this case you just need an rca cable for the front speakers amp and an rca cable for the rear speakers amp.
I'm not sure i get what you are trying to do, sorry if i confused you myself, just repost with more info and i'm sure there'll be plenty of peeps that can help you.
The Standard One
"i am hooking up pionner 200 watt amps to every pair of speakers"
i think its just a typo. he meant 2 pairs... maybe he's using 2 - 2 channel amps? not sure why but i just answered his question
hah no nothing is a typo but its not for a civic i have those pairs and then i have a set of subs already hooked up. my car has 2 pairs on the rear channel and 2 on the front right now and i am about to amp all of them. so u guys think the best thing to do is run 2 pairs of rcas to the back and then split them b4 =they get to the amp? and i am using 4 2 channel amps btw. yes i know about the power problem :-x i am jsut hopiing it will be alright
hahah can 1 battery power 5 amps?!?! IT BETTER
sike i have an extra battery laying around if theres a problem
sike i have an extra battery laying around if theres a problem Last edited by khmaitiger; Jun 6, 2003 at 10:13 PM.
Hutch1051
Sep 29, 2015 09:20 AM
redcloud
Sep 7, 2015 01:45 PM
