problem installing dead unit - dash lights not working now
Old May 25, 2002
astigmatik's Avatar
astigmatik is an unknown quantity at this point
ok i installed my deck it was working until i screwed everthing back in.
now my dash does not light up, cd does not work, and keyless entry doesn't work either.
i checked some fuses and they were ok. anyone know what could be the problem?
oh, and my srs light is on too.
thanks.
Old May 25, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
dude take out your center console and plug those three plugs back into the heater/controls unit . one of them came unplugged whne you ere installing it no big deal it shouldnt take you more than 10 mins to fix =) good lu8ck!
Old May 26, 2002
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
Did you check the fuses under the hood. The fuse box is by the battery. That same thing happened to me when I installed my HU. Now I know why they say disconnect the battery terminal.
Old May 26, 2002
astigmatik's Avatar
i checked the fuses and the backup fuse was blown. now everything works except the dash lights!
Old May 26, 2002
mohawkboom's Avatar
then you blew your dash panel.. drive to honda.. bring alotta $$$$
Old May 26, 2002
astigmatik's Avatar
mohawk, how do they repair the dash lights? what does "blew the dash panel" mean exactly.
hopefully i can weasel my way to have it repaired under warranty.
Old May 26, 2002
DaveyD's Avatar
Mr. Negative
If you want to weasel your way into them fixing it, put in your old unit, tell them you dont know what happened.
Old Jul 31, 2002
HondaCoupe's Avatar
HondaCoupe is an unknown quantity at this point
im sure you already fixed the problem...when people have this happen after putting in a new CD deck they usually run the dimmer wire to the CD player to the wrong wire so it sends a power signal back to the dash shuttin it off
tylerginevan
Apr 27, 2015 12:29 PM
Linda0818
Apr 23, 2015 11:30 AM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
