rear power window driver side problem
Rep Power: 0 rear power window driver side problem
My rear window has stopped rolling down... When I apply direct 12 volt power to the regulator it goes up and down fine and the switch shows appropriate continuity in both directions and the fuse under the das aren't blown.. Ideas??
Re: rear power window driver side problem
Broken wire in the rear door jamb where the harness flexes every time you open the door?
ej8
04-13-2015 06:36 PM
EXWisdom
11-05-2001 10:24 PM
