2001 Civic EX rear window defroster not working
Rep Power: 0 2001 Civic EX rear window defroster not working
The rear window defroster of my 2001 Civic EX doesn't work. Replacing the burned out fuse promptly failed. I opened a little access plate in the molding along the window and found where two wires connected to the defroster with spade connectors. One of the spade connectors was very reluctant to come off, and once it did I saw a crusty buildup. I caution everyone that the copper spade connectors of the defroster grid are very thin, bend and easily break off. This happened to me even though I was very careful. So I cut off the female spade connector of the wire, thoroughly cleaned the base of the broken male spade with sandpaper and soldered the wire to it. But I still keeps blowing fuses. Has anyone else in here had this problem? Please, how did you fix this? Thank you.
Rep Power: 0 Re: 2001 Civic EX rear window defroster not working
Craig:
I'm sorry I'm late in answering as I've been slammed lately. If I try to use the defroster nothing happens and any fuse I use fails, so yes, I suppose my fuses blow right away.
A short circuit could be tough to track down for certain... It could be quite $$ in labor.
Knowing if the fuse opens when you switch the key to II... or when you push the defrost button will sort of cut it into 2 sections.
I have been turning the engine on and then pressing the defroster button. I didn't occur to me to check the fuse after just turning the key to auxiliary power to see if the fuse blows. I'll try to narrow this down. Thank you.
mattdoc
03-14-2017 12:10 PM
lilbluecivic
11-07-2001 06:49 PM
