help with ohms
Old May 2, 2002
Nj's Avatar
Nj
Nj is an unknown quantity at this point
help with ohms
I have been on crutchfields website looking for a pair of subs. I see 8 ohms, 4 ohms, & 2 ohms. I saw a post on this site that said something like two 4 ohms subs in parallel = 2 ohms. So would two 8 ohms subs setup the same way = 4ohms? I would like to do the custom trunk setup I saw on this msg board but I would like to use 10's instead of 12's. so should I look for two 4ohm subs or two 2 ohm subs? One more thing I should use a mono amp with those right?
Old May 2, 2002
mohawkboom's Avatar
there's you should use... It all depends on the amp you have. If the amp is 2ohm mono stable.. then 2 SVC 4ohm subs wired in paralell would be good. If you get an amp that's 4phm mono stable. when 2 DVC 4phm subs or 2 8phm subs would do it..
go to JL's site Click on tuturials..they have a HUGE listing of different sub wiring options and pictograms.
Old May 2, 2002
Nj's Avatar
Nj
mohawkboom what do you think about kenwood head units? I am looking at 2 that they make.
kenwood kdc319
kenwood kdc419
i almost got the 319 today. Then i thought let me go home and ask the people from the group. Keep in mind I dont have a whole lot of money. So a head unit in the 200 range is about as high as I can go. Thanks for your help everyone
Nj
JetsterDajet
52
May 8, 2016 12:11 AM
Bruce2
Sep 21, 2015 08:01 PM
alvinecigs
Air Conditioning
120
Sep 20, 2015 03:47 PM
Jul 12, 2015 11:54 AM
