mounting components
Old Apr 30, 2002
ziggyziggy69's Avatar
ziggyziggy69 is an unknown quantity at this point
mounting components
where is the place that people usually attach the crossovers to? assuming that i want it out of sight.
Old Apr 30, 2002
CivicRiderCA's Avatar
CivicRiderCA is an unknown quantity at this point
Well, I put mine in the trunk and worked it into my scheme.... But a lot of people put them under the driver seat; use 3M double sided foam tape to put them on the inside of the cover under the steering wheel (the panel that covers the fuse box); I've even heard of people using that same foam tape and mounting them on the insde of the door panel iteself!
Pretty much anywhere in the car.
Old Apr 30, 2002
if i mount my components on my doors and sail panels, i would have to run quite a bit of wire back and forth to the trunk. as for hiding it under the seat, i think it is quite hard to run the wire from the doors there and still have the wires out of site. i would prefer to mount them inside the door panels if possible and safe.
Old Apr 30, 2002
mohawkboom's Avatar
I have mine mounted inside the door panels. most people do.. almost all shops do that..saves on wiring and space..
Old Apr 30, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
yeah me too there is a big cut out in the doors i think where the sida airbags would go or something and these plenty of room. then just snake one wire in to the door from your amp and your set
Old Apr 30, 2002
i thought the side airbags are in the seats?? anyways, i guess i can just tape the crossovers inside the panels right?? or is it better to use screws??
Old Apr 30, 2002
mohawkboom's Avatar
I used Velcro
Old Apr 30, 2002
is velcro strong enuf?? how heavy is the crossover? i once tried to use velcro to mount my receiver's remote and it kept falling off.
Old Apr 30, 2002
mohawkboom's Avatar
Velco's enough.. most componentscome with 4 strips of adhesive backed velcro allready..
Old Apr 30, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
ziggy, get some better velcro. lol.
Old Apr 30, 2002
damn i guess i paid so much for the 3m industrial kind for no reason.
Old Apr 30, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
I used zip ties to those square sticky things...forgot their name.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
ZoSoIV
Sep 17, 2015 07:17 PM
FistRock
Sep 4, 2015 08:00 PM
