2005 Honda Civic stereo wiring question (specific)
Old Jun 23, 2007
tomjoyce's Avatar
tomjoyce is an unknown quantity at this point
Question 2005 Honda Civic stereo wiring question (specific)
Hi.
I have a 2005 Honda Civic ValuePackage (don't laugh). I'm planning to purchase a new head unit and install it myself. When looking at the wiring diagram from the new head unit (Pioneer DEHP3900MP) and the vehicle wiring chart from the12volt.com ... http://www.the12volt.com/installbay/....asp~TID~86090 ... it appears as though there are more wires to connect to the factory stereo than the new aftermarket one. What do I do with the leftover stereo parts?
My car should have these wires (no tweeters installed):
+12V DC Battery(Constant), Switched Accessory, Ground, Illumination, Left Front +, Left Front -, Right Front +, Right Front -, Left Rear +, Left Rear -, Right Rear +, Right Rear -...
There is no mention of an antenna plug on the12volt ... i do have one separate that will fit my new Pioneer HU, right?
What do I do with the "Illumination" wire? Leave it unplugged from anything? ... please don't mention a wiring harness, I am going to do without. Don't worry, I am going to keep the factory wiring harness with the factory stereo, should I ever want to put it back in. Thank you for your respect of my wishes, and your help!
Old Jun 23, 2007
tomjoyce's Avatar
Re: 2005 Honda Civic stereo wiring question (specific)
Oh shoot, that was my other question. Can I just connect the ground wire from the car to the ground wire on the Pioneer wiring harness that comes with the HU?
Old Jun 23, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
ok so you do know u still have to cut off the connector if arent going to use a harness. i suggest u break down, buy a cheap harness and make things so much easier. but are u saying ur new deck doesnt have an illumination wire? and ur antenna wire is separate from the harness. ur ground wire should be in the harness. maybe this will help
Cavity Wire Connects to
1 YEL/GRN Antenna module
2 YEL/RED ACC (Main stereo power supply)
3 - Not used
4 - Not used
5 PNK Right rear speaker (+)
6 BLU/WHT Left rear speaker (+)
7 GRN/YEL Passenger's door speaker (+), Right tweeter (+)
8 GRN/BLK Driver's door speaker (+), Left tweeter (+)
9 RED/BLK Lights-on signal
10 WHT/RED Constant power
11 - Not used
12 - Not used
13 - Not used
14 - Not used
15 BLU/YEL Right rear speaker (-)
16 BLU/BLK Left rear speaker (-)
17 GRY/RED Passenger's door speaker (-), Right tweeter (-)
18 LT GRN Driver's door speaker (-), Left tweeter (-)
19 RED Dash lights brightness controller
20 BLK Ground (G503)
Old Jun 23, 2007
speedfoos's Avatar
^^^ Good post, but you're right. Screw all that splicing garbage and buy this off Ebay:
Honda Civic Stereo adapter harness thing
This way you don't have cut the factory harness off and it makes installs sooooo much easier.
I know you said not to mention a wiring harness, but why put yourself through all that hassle?
And it costs 8 bucks shipped to your door.
Old Jun 23, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
You don't have to cut the plug off if you want to hardwire but trust me, having done it plenty, you'd rather just use the harness.
Old Jun 25, 2007
electric130's Avatar
buy a harness
Old Jun 27, 2007
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Why WOULDN'T you want to use a harness? Then it's just a matter of matching colors, then tape off what you don't need.
Done.
Metalviper: That's a sweet drawing.
Old Jun 27, 2007
speedfoos's Avatar
If you cut your harness off, leave about 3 inches of wire off the end of it and sell it to me. The moron who owned my car before cut the harness off when he wired the car and I am not looking forward to when I have to upgrade the stereo.
Old Jun 28, 2007
tomjoyce's Avatar
1. thanks guys but too late. I already cut the stock stereo harness off.
2. Sorry speedfoos, but I'm keeping it, and the stock stereo. I might put it back in when I go to college, if my parents don't let me take the car with me. I'm trying to do everything so I can return to stock, and take all my invested $$ with me. :-)
But thanks for the help guys, the stereo sounds GREAT! :-) With the factory stereo, I was missing a lot of the low notes on some songs I listen to (not even a distorted sound, a complete lack of sound where there should be sound)... and they now come through great, even with stock speakers. Don't worry, I'll be upgrading speakers soon and getting an amp and 2 subs.
Old Jun 8, 2011
metalshredder's Avatar
metalshredder is an unknown quantity at this point
Yep, it was a very bad decision to go this route. I'm in the same boat as Speedfoos, some jackass hard wired the radio before I got the car. I don't know if it was stolen or if the installer was just a retarded *******. Maybe both.
Anyway, can someone explain the function of Pin 1 for me? Is this to power the antenna booster or whatever it is? I'm having real shitty radio reception and i have a feeling that because they hard-wired, might have left it disconnected.
If this IS the pin that powers the antenna booster, would I hook it to....the power antenna lead on the radio, or what exactly?
Old Jun 8, 2011
yes.
Old Jun 9, 2011
Well that didn't seem to help...
Old Jun 9, 2011
what didn't help? be more specific?
Old Jun 9, 2011
Well, I hooked the remote turn on / power antenna wire (blue) from the back of the radio to pin 1, expecting this to power up tue antenna booster and give me radio reception, but, no such luck. No dice.
Old Jun 14, 2011
You have coupe or sedan?
Old Jun 14, 2011
It's the coupe.
Old Dec 9, 2015
jorge71's Avatar
jorge71 is an unknown quantity at this point
Sorry i have a mp3 from walmart is like a stereo just comming with the speakers wires and 4 other ones red ,black ,yellow and blue , i don't know jow i have to put the wires because the ep3 have 2 wires with power the first is white and red ,the second is yellow and red.thanks
Old Apr 20, 2020
civicnoob123's Avatar
civicnoob123 is an unknown quantity at this point
Hey guys - im losing my mind over here. I have a 2005 civic ex sedan and this all started when the stock radio threw a code. i figured id just replace the head unit. I got a cheap blaupunkt stereo but I dont think thats the issue. First things first the rear speakers dont work at all. wiring looks good but i haven't checked for a short. I tried switching positive and negative to see if the polarity was reversed and tried tying the rear speakers into the front speaker wires and still nothing. figured front speakers were fine for now until i could investigate more and now the head unit wont power on. whats going on? do I have a ground issue? a short somewhere? I also saw some posts of people tying the blue antenna wire into another - whats that about?
The wiring in my car is the left and the blaupunkt is the right (Application. | Honda Stock Color | Blaupunkt wire):
+12V DC Battery(Constant) | WHITE/ red | Yellow
Switched Accessory | Yellow/red | Red
Ground | Black | Black
Dimmer | Red | no match to connect- capped.
Illumination | RED / black | no match to connect - capped.
Left Front + | GREEN/ black | White
Left Front - | Light green | White/Blk Stripe
Right Front + | GREEN/ YELLOW | Gray
Right Front - | Gray/red | Gray/Blk
Left Rear + | Blue/white | Green
Left Rear - | Blue/black | Green/Blk
Right Rear + | Pink | Purple
Right Rear - | Blue / YELLOW | Purple/Blk
Power Antenna | N/A capped | Blue
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
twtron
Apr 17, 2015 12:09 AM
gabrown2
Apr 11, 2015 08:22 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
