wire color code to the remote mirror switch?
Old Jun 22, 2007
lettcco's Avatar
lettcco is an unknown quantity at this point
hello, does anyone know the wire color code to the remote mirror switch? my up and down stop working, tried replacing with a new switch but still the same, so I need to do some continuity test...
TIA! it's a 2001 civic LX coupe BTW.
Old Jun 23, 2007
CraigW's Avatar
Re: wire color code to the remote mirror switch?
Here is some info on the mirrors circuit.
File Type: pdf
File Type: pdf
Old Jun 24, 2007
lettcco's Avatar
Thank you CraigW! That's exactly what I needed! I track down the culprit and it's the bluegreen wire not sitted in the switched connector. Unforntunately when I try to fix the pin I also bent it pretty bad along with the connector.
Where can I buy the pins and connector? I don't want to buy the whole harness...
Old Jun 24, 2007
CraigW's Avatar
My thinking is you have to get sections of harness and the connectors are attached. (Honda parts prices are reasonable in most cases)
Is it the connector at back of switch ?? (if so that may be tough)
If you have a wire on each side of connector available and enough room...You could use insulated spade terminals (male and female) and bypass one wire of the connector.
Old Jun 26, 2007
lettcco's Avatar
Just thought I would keep you inform on what happened to my story. long story short, I attached a new pin onto green/white wire and re-insert it into the harness connector, reattach the switch onto the harness. Still no go. At this point I want to re-examine my switch (I did replaced the switch with a brand new one from dealer so I didn't even give it a second thought). all the other contact besides green/white are short to ground when not switch...so I ended up pry open the switch and have a look...bingo!
the PCB has a weak point and I guess the current is too much to handle. So I grabbed a solder iron and solder a wire between the 2 contact, put everything together...and now it works!
Thanks again for the schematics, craigW!
CraigW
May 24, 2015 09:49 AM
darwin-t
Apr 18, 2015 09:29 PM
Jimmy24
61
Sep 15, 2005 11:15 AM
AlpineCivic
111
Oct 20, 2003 07:31 PM
klam
Nov 16, 2001 03:36 PM
