unknown plug
Old Feb 12, 2007
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
unknown plug
i was changing a lightbulb today and noticed this plug. it's on the same loom as the turnsignal/running light. but is taped with blue tape to the harness. fairly thick wire mabye 16-14 gauge. one pin conector with blue/red stripe.
anyone know what it's for? foglights?
BTW it's a 02 EX coupe
heres a pic of what i'm talking about
Old Feb 13, 2007
sentbacktothesu's Avatar
sentbacktothesu is an unknown quantity at this point
it might be side markers. ive seen kits that just plug into the harness like that.
Old Feb 13, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
stick a test light in it and turn the headlights on. if the test light doesnt light up, try the turn signals.
Old Feb 13, 2007
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
That's the wire you use if you buy the OEM foglight kit, it will plug into the wire going to the foglights.
Old Feb 13, 2007
hwt101's Avatar
hwt101 is an unknown quantity at this point
Do all ex's come "prewired" like that?
Old Feb 13, 2007
EG06KRS's Avatar
EG06KRS is an unknown quantity at this point
Mine is like that. I saw it after someone ran me off the road and i hit a poll. haha
Old Feb 13, 2007
claudeboi's Avatar
im a psychopath...what are you looking at?
claudeboi is an unknown quantity at this point
mmmmm I think you need new tires
Old Feb 13, 2007
soldierboi's Avatar
soldierboi will become famous soon enoughsoldierboi will become famous soon enough
i think mine is like that...im not sure but ill go check as soon as i can tomorrow.
Old Feb 13, 2007
hwt101's Avatar
sweet, so when you buy the fog light kit form honda there are no wires to run its plug and go?
Old Feb 13, 2007
DieMaster's Avatar
if the tire is slick then u have better tracton and better handling :P
no there just warn on the outside lip. the tires pass the "lincoln head" test in the center.
Old Feb 13, 2007
DieMaster's Avatar
ok just did some checks.
i checked the fuse/relay locatons in the OEM instructons for foglights. nothing there. no switch plug in switch locatons. no red/wht wire on headlight switch. thus no fog wiring.
there IS NOT a conector like that on the drivers side. however there is a blue/red wire going to the horn from the same harness. same wire size. my guess is that on EDM cars your required to have a horn on each side. that might be whats it's for.
Old Feb 13, 2007
hwt101's Avatar
even sweeter i have been thinking about hooking up an F350 horn but i can now have 2 weenie horns instead
Old Feb 13, 2007
Taffy's Avatar
If you try to hook up a horn to this wire you are in for a big headache. It's for the foglights.
The other side of this plug is underneath the center console under the cupholders. You gotta look for it though. I was trying to use this when I was hooking up my fogs, but just decided to run my own wires.
Old Feb 14, 2007
hwt101's Avatar
+1 for you PD
SimpleUser
Apr 24, 2021 02:54 AM
mikey1
21
Aug 27, 2015 06:38 AM
fecrni
Aug 8, 2015 06:15 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
MamaBear2015
Jul 3, 2015 11:26 PM
