Amp Problem
Old Feb 17, 2006
blackBDMcivicLX's Avatar
For every sprinkle I find, I shall kill you.
blackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant future
Amp Problem
I have an amp that belonged to my brother awhile back (Legacy, junk I know), but when the key was in the acc position (motor off) it worked fine. As soon as the car would turn on (motor on) it wouldn't work. I'm stumped at what could possibly be wrong with it that it does that. Any ideas?
Old Feb 17, 2006
someone didn't wire the remote turn wire properly. they prolly tapped it off the ignition cause they were too lazy to take out the radio and connect it to the remote wire.
Old Feb 17, 2006
No its not that bc It did it in his car and then in my car and I wired mine myself. And my amp i keep in the car works fine.
Old Feb 17, 2006
okay try this unhook the amp and open the hood. run two separate power wires from the battery + to the power and remote terminals. then run a ground from - battery to amp ground. see if the amp comes on. if it does, your wiring is bad in the car. if it doesn't the amp is bad.
Old Feb 17, 2006
ok i'll give it a try and get back to you, thanks!
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
