Sub/Amp problem
Old Feb 7, 2002
TroyA's Avatar
TroyA is an unknown quantity at this point
Sub/Amp problem
Okay I've got the kenwood KAC-929s 1000watt amp. powering a 12" Infinity 1220watt sub.
It was all working fine, then, one day it just stops working, now the sub still plays but it's kind of scratchy and it can't hit the low notes and the amp protection circuit keeps cutting in with the really deep bass.
I've checked all the wires and everythings looking fine..
did I blow the Sub? it's rated at 300 watts with a peak of 1200 watts
my amp is bridged and buts out 460 watts with a max of 1000 watts.
it's a long shot but it's the only thing I can think of... anyone got a clue what went wrong?
Old Feb 7, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
hmmmm you may have blown the sub. Nice to see someone else from edmonton. you should goto the Canada west forum. There's lots goin on there with a few of us edmontonians. We're even starting a car club! Anyhow. If you bought your sub from futureshop, i suggest you go back there and bitch. I know they carry both your amp and that sub. heheh, my new setup from them is actually decent. I picked up an MTX 8000 12" for 200 bucks. I think they have another one and it can hack the power your amp puts out (I'm feeding mine 500rms from a Phoenix Gold).
Old Feb 7, 2002
VNlilMAN's Avatar
The Standard One
the amp protection thing shouldnt come on if you have blown subs...
Old Feb 7, 2002
TroyA's Avatar
I was hoping to avoid dealing with futureshop as much as possible.......somehow I doubt that they will be all that helpful....
I'm still curious if it should be even possible for me to blow the sub, if it can handle a max of 1200 watts surely it should be able to take 460 watts for an extended period of time. or is the 300 watt nominal rating a guideline carved in stone?
If the sub is blown I'd like to know the math before i buy a new sub, that way i'll know if I have to find one with a nominal rating well above the 460 watts my amp puts out.
Old Feb 7, 2002
mohawkboom's Avatar
You Blew the sub..the scratchy noise iis the voice coil scraping on the motor structure... Sub go Bye Bye,, [IMG]i/expressions/face-icon-small-smile.gif[/IMG]..
If it's rated at 1200Wrms Peak.. Future shop should cover it undr warranty.
Cheers
Mohawk
Old Feb 8, 2002
Yea, i already had my MTX 8000 Replaced by futureshop, and I've had it for umm 3 days now i think. They replaced it with little resistance. haha, might have been because i just bought it the day before, but you can usually push em around a bit.
Old Feb 11, 2002
TroyA's Avatar
okay I managed to get futureshop to take my sub back........... which means i've pretty much nuetered my system...
I'm looking for a 12" sub (so I don't have to build another box), that can handle 460 watt RMS, 1000 watt peak.
With a good mixture of quality and pound.
Money isn't really an issue.
Any suggestions?
so far I've looked at the:
MTx 8000
Orion XTRpro 12
Infinity Perfect 12.1
Phoenix Gold XMAX 12
Old Feb 11, 2002
I'd go with the perfect. unless futureshop southside still has the MTX 8000 for 199. i bought one of em. and it pounds with 500rms. they had two.
Old Feb 12, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
Depends on how much money you want to spend. Look into a nice JL W6 300rms, W7 750, Rockford Power HX2 150-1000rms, or maybe some L7's 350rms. All will cost you over 200 if you shop around you can get an excellent deal.
Old Feb 12, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
That MTX8000 for $200 sounds like a great deal. those are supposed to be great subs and I know it can take the power. The RF Power HX2's are nice. that's what I am getting. they can definitely take the power.
Old Feb 12, 2002
scsikid's Avatar
scsikid is an unknown quantity at this point
i worked for futureshop for 3 years. they will take back anything .... if u yell loud enough!.
hehehh i hate that place!!
Old Feb 13, 2002
2K1SilverHX's Avatar
2K1SilverHX is an unknown quantity at this point
Personally I'd go with Eclipse Titanium subs... or the new JL W7... Both tight subs
Old Feb 13, 2002
how about IDMAX? i've heard bad things about the W7s. IDMAX is evidently better. I've had a thread on this already.
Old Feb 13, 2002
TroyA's Avatar
I'm leaning heavily toward either the Infinity or the IDMAX.
It's next to impossible to find any local place which carries the IDMAX...
I have store credit at futureshop, which i would like to use, but they have no clue when they'll be ordering in new Infinity's...
When i asked about IDMAX I just got a long pause and a blank stare.....I think I need to find some better stores.....
Old Feb 13, 2002
yea. I don't know where to get IDMAX in this province either. but they cost about 800 a sub. just so you know. Also. Did you check for MTX 8000s at the Futureshop on Calgary Trail. they might have one for 200 bucks. they did last week.
Old Feb 15, 2002
hey troy. if you want, i'll sell you my MTX 8000 12" with a 2yr extended warranty. hit me back soon. $220 without box, 300 with box. CDN.
Old Feb 15, 2002
Tracie's Avatar
Tracie is an unknown quantity at this point
You might not have blown the sub. The same thing happen to me. My sub was working fine, but stopped. I thought I blown the sub but the amp was faulty. I had my boyfriend tested the sub it was fine, he tested the amp and the crossover burned out. So we got it replaced and it was bumpin again. Although if your speaker has a really high distorting noise when in use with a good amp then your sub is probably blown. Sorry.
Old Feb 19, 2002
TroyA's Avatar
Well I got impulsive and tracked down an Infinity Perfect at a futureshop across town ( they literally pulled it off the truck for me).
My system is back and running fine, although I'm only powering the sub at 1/2 of what it could take....
i might update the amp one day, but right now I'm saving for a Honda CRX......then I'll need a system for it too...........
thanks for all the help everyone.
Old Feb 19, 2002
yea, i thought they had perfects at the Edmonton South location? they did when i was last there. but good for you. those are great. I'm returning this MTX, and selling my amp. then i'll go systemless till i can afford an IDMAX, for 800, plus a Phoenix Gold 1000watt Class D amp for it!
BTW, how are you underdriving the Perfect? don't you have like 460RMS? if your going by the 1400 watt number that's the max output. That's how you blew your last sub isn't it?
Old Feb 22, 2002
TroyA's Avatar
I spent a couple hours with the install guys, (I wanted them to check my install to see if I screwed up anything, before I put another sub in)
Apparently the south built a demo vehicle, where they were running 1000 watts each into 2 perfects and had no problems...the trick was just making sure that the box was perfectly air tight and measured exactly to keep the cone from overextending itself and heating up.
Of course everything is half power to some of those install guys, unless glass is shattering and your ears are bleeding.
Old Feb 22, 2002
hmm sounds good to me. anyhow. off topic now. are you ever going to come meet with any of us 2k1 owners in Edmonton (Asianpride, Damian2k1, Blown, Dret, Myself, and a few others). We get together somewhat often now (well at least Asianpride, Damian, and I do), and we are even in the process of starting up a car club. Just come down to Canada West, and post a thread.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
