help with headunit install...
Old Feb 12, 2005
fasssstjapbike's Avatar
fasssstjapbike is an unknown quantity at this point
I'm trying to do the install on my 04 civic ex coupe m/t. I got the whole center console up and removed the two screws on the mounting bar, but no matter how hard i push I cant get the headunit to pop out. Only one holding pin popped out so far but i got that one out by prying. I've tried pushing, pulling and prying with no luck at all. I know i'm pushing on the right piece (not the one thats fixed) b/c i can see the head unit moving. Anybody got any tips on how to get this out. I know it says on the DIY that its hard but damn, its making me feel like a little girl. Any help/tips appreciated
Old Feb 12, 2005
MegaHurtz's Avatar
push harder you wimp!!!!!!!!!!
j/k, but seriously it can be quite stiff the first time removing it, just push with all your might and success will prevail.
Old Feb 12, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
Push on the metal piece where the two 10mm bolts are. Pulls towards your. Reach underneath and pull till the console gets loose.
Old Feb 12, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
If you work at it, you'll loosing it. It takes a little time. Take a screwdriver, tape the end with electrical tape to make it softer and VERY CARFULLY pry just above the vents. If you twist and pry you'll pop it loose. I also popped the Air vents out and pulled from there too.
Old Feb 12, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Or, buy a plastic spackel (SP?) filler from a hardware store. ($3 at harbor freight). These make great panel poppers.
Old Feb 13, 2005
Thanks guys, I got so frustrated that I couldnt fit my hands in there that I took out the glove box and use a big *** screwdriver as levrage and it popped right out. My hands hurt too much before cause it was so damn cold outside here in NY.
PS2Wayne
Jul 15, 2002 12:46 AM
ZSKCivic01
May 7, 2002 02:41 AM
djaber
Mar 28, 2002 01:12 PM
Foom
Dec 6, 2001 01:11 PM
