amp issues
Old Aug 5, 2004
black04's Avatar
black04 is an unknown quantity at this point
amp issues
I recently installed an amp a few weeks ago and worked until now. The only issue i had before was every so often my amp/sub? would pause for a second then it would produce sound again. The amp didnt go into protection while it did that either. But now i have a bigger problem cause the amp will not even turn on now. What are the step i should go though to troubleshoot my power problem? I just checked all of the wiring and it looked fine and i even made a new/better grounding location.
Old Aug 5, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
make sure you are geting power to the remote wire, check the fuses and power at the amp. If everything is fine, it could be the amp. I would have to see it. where in mass are you?
Old Aug 5, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Sounds like a loose connection somewhere ...
Old Aug 5, 2004
MegaHurtz's Avatar
Does the amp shut off or merely stop producing sound?
Old Aug 5, 2004
black04's Avatar
im in methuen
Megahurtz: when i had that problem it just stop producing sound but now its no longer the problem since the amp dont turn on
Old Aug 5, 2004
MegaHurtz's Avatar
Double and triple check ALL connections
Is it your sub only that cuts out? Or all speakers?
Old Aug 5, 2004
black04's Avatar
its just the sub my speakers are still stock
Old Aug 5, 2004
MegaHurtz's Avatar
Yeah check the connections before we move further
Old Aug 6, 2004
black04's Avatar
it just so happens that today i go to look over my connections again and before i even had a chance to i turn on my system for the second time today and it works. kinda weird
roverben
Jan 21, 2019 05:16 PM
jackoncruzpr
May 24, 2015 12:24 AM
WLakers
May 4, 2015 06:23 PM
NeonNights
Jan 23, 2002 09:50 AM
SLeePeR012
Jan 7, 2002 12:24 AM
