How to pull this panel off? (pic)
Old Mar 28, 2004
MegaHurtz's Avatar
I was just reading a DIY on how to take my stereo out, and I am not sure on how to take this one panel off without wrecking it.... seems really hard to take off by hand, so I don't want to mess it up by pulling too hard...
Picture of the panel is here:
http://members.***.net/stuartk20/civic/4.jpg
and the full DIY (including an underside pic of said panel), is here:
http://www.vancouvercivics.com/forum...d.php?tid=9240
Please help, thanks.
Old Mar 28, 2004
LudlamTheory's Avatar
i boogie for the raindrops
pull hard. it should come off with the panel behind it that surrounds the e-brake too...
Old Mar 28, 2004
MegaHurtz's Avatar
Where should I apply force though? At the front of the panel? At the back? In the area around the shifter?
Old Mar 28, 2004
WhiteRabbit's Avatar
where you see those square holes, thats where the panel is attatched
Old Mar 28, 2004
MegaHurtz's Avatar
turns out i didnt need to fully remove the panel, i just muscled it out mof the way enough to get a screwdriver in to take the screws out... everything else went... well okay... deck isall wired up and ready to go back in now! thanks for the help
Old Mar 29, 2004
tom1178's Avatar
tom1178 is an unknown quantity at this point
Man i wish i had an 04 civic, i can't stand having the entire center console being unscrewed and pulled away just to get the HU out. The two bolts at the back and on the sides of the center console, people with 02's will know....the two bolts that are basically in the front of the back seat area of the car, i haven't had those screws bolted in for over a yr. Ok this whole front back side of back front rear stuff has even gotten myself confused...nevermind.
Old Mar 29, 2004
MegaHurtz's Avatar
^^ LOL
Old Mar 30, 2004
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
Heh Tom you dont need to take that all apart if your careful. 02's are jus as easy as 01's if you pop the cigertte lighter panel out careful and pull up and out.
Old Mar 30, 2004
tom1178's Avatar
I guess i'll try that next time i need to get back there.....there just doesn't seem to be much room for error.
OPGForce
Exterior DIY
125
May 20, 2019 04:11 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
KronikScott
Jun 9, 2015 08:00 PM
ImmortalEX
Nov 8, 2001 09:52 PM
