Wiring Question
Old Jul 1, 2003
chriscivic's Avatar
chriscivic is an unknown quantity at this point
Wiring Question
I plan on getting 2 apine type e's or s's both rated 5-200 rms watts a piece.
ALso getting an alpine amp. 200x1 rms at 4 ohm, 350x1 at 2 ohm.
How do i wire the two together to the amp to be the most efficent(most power).
I have no idea of any wiring to get the right ohms and stuff
Thanks
Chris
A wiring diagram woud be great
Old Jul 1, 2003
ga4dr's Avatar
ga4dr is an unknown quantity at this point
tie both the positives together then both negatives together. run the two positives to the positive out put on the amp. then run both negative wires to the negatve out put on the amp.
Old Jul 1, 2003
Bellz's Avatar
Am I resourceful or what??
Old Jul 1, 2003
chriscivic's Avatar
How many ohms does that come out as on the type e's or r's is it 2 ohm?
Old Jul 1, 2003
Bellz's Avatar
From the same source as that diagram:
"Note that the impedance of two speakers in parallel will be one-half the rating of the subs, if both speakers are of the same impedance. This will result in a greater load being placed on your amplifier, so it is a good idea to make sure that the amp is stable for this lower impedance."
So, if they're 4ohm speakers, you're bringing them down to 2ohms. Most quality amps are 2ohm stable, but check their specs to make sure.
Old Jul 1, 2003
chriscivic's Avatar
What if i wire in series?
Old Jul 1, 2003
Bellz's Avatar
"Please see the diagram below, and note that the total load impedance will be the sum of the impedance of each speaker. This results in an easier load for the amplifier, resulting in cooler operation and cleaner signal, but less power output."
In this case, the 4ohm speakers will be 8ohms and draw less power and produce less power.
Old Jul 1, 2003
Bellz's Avatar
FYI:I got that from the tech FAQ at crutchfields site. It's what popped up when i Google-searched it.
Old Jul 1, 2003
chriscivic's Avatar
Thanks alot, thats what i needed to know
Old Jul 1, 2003
Bellz's Avatar
No problem man. Post some pics when you get them installed.
juror
Jun 9, 2015 02:15 PM
werdnahall
May 17, 2015 11:37 AM
pincookie1
May 4, 2015 12:22 PM
viper775
Dec 9, 2001 10:52 PM
klam
Nov 16, 2001 03:36 PM
