r18 turbo
Rep Power: 0 r18 turbo
I have a 2006 civic ex coupe and im pretty sure its a r18.. I have a TDO5H 1G turbo from a talon and I have been searching around to find a way to use it on my r18. Would it work? Any advice? Also is it possible to remove the manifold or is it welded to the block?
Rep Power: 0 Re: r18 turbo
Help this guy please
lol!
Will work that, but there is a turbo kit for your car bro
or you can do it your self and get part by part
lol!
Low and slow!
1 Post
Rep Power: 190 Re: r18 turbo
The turbocharger itself will work but you will probably have to make a custom turbo manifold to use it. I dont think that a civic turbo mani would work with it. And the exhaust manifold is not welded to the head. The exhaust mani is just held on with bolts.
alright i have no idea what size intercooler and down piping I would need and what material... I am going to do it custom because I dont feel like spending 2,000 on a whole kit. Any recommendations on how to make a custom manifold or what would work on the r18
Good luck spending under 2000. The tuning is what’s going to bend you over and leave you with a hemorrhoid. For my hatch it cost about 600 for a hondata s300 and if you get it tuned (professionally) which I recommend, it will run you another 400. Correct me if I am wrong, but for an R18 you need Kpro which costs even more.
If it were me, which I learned my lesson when I boosted D17 for 1,900 (lasted a month) save up some money. I put together a legit amount of money and boosted a B18c hatch and I have yet to have any problems with my setup.
But I could be wrong... I hope that what happened to me dosnt happen to you.
7thgen Power Maker
1 Post
IC pipes, aluminum 6061 and since the snail is small, keep the pipes small like 2.25"
http://www.dezod.com/cat-aluminum-bends.cfm
Re: r18 turbo
Im currently running a Jotech Kit with a 5857 precision turbo @ 9 psi pushing 276 whp /249 wtq
Jaryn
05-17-2016 02:52 AM
