LED Bulbs for Headlights 2009 Civic
Rep Power: 0 LED Bulbs for Headlights 2009 Civic
Afternoon All,
Any insight would be greatly appreciated.
I have been wanting to upgrade my vehicles lighting to all LED's without changing the housings. I went onto Amazon and bought these. http://www.amazon.com/9006-Super-Bri...s=9006+hb4+led
However due to the little plastic reflector dish inside it loses about 50% of its lighting capabilities. Does anyone have any bulbs from a certain company or manufacturer they can recommend? I am also going to do my auto and high beam bulbs too, however after purchasing these i'm leaning away. Any tips?
Re: LED Bulbs for Headlights 2009 Civic
If you install LEDs on the high beams it may freak out the MICU and turn on the DRL warning light on the dash, same as when someone tries to use HID lights there. You may want to check into using decoders if that happens.
The current LEDs are not designed to be used in the reflector housings of halogen lamps. They project the light differently and end up having very poor visibility for you as well as abundance of glare for oncoming drivers. The only good thing is that the light looks bright and cool while looking from outside the car. If you really want to improve the lighting performance, then options are putting higher wattage halogen bulbs (if necessary by using a relay harness) or doing an HID projector retrofit (if you prefer performance + cool looks). Don't waste your time and money on half hearted attempts which will never give you the expected performance. Good luck.
I'm going HID 8000K bulb 9005 (HB3) - 8000k
1 Post
Rep Power: 117 Re: LED Bulbs for Headlights 2009 Civic
Response to an old post: I will be replacing my head light assemblies with OEM assemblies, I was thinking of these LEDs with the anti flicker device for the low beams. But aren't reading anything that makes me feel good about the $175 cost. Any input is welcome, seems like an LED replacement would be mature now days, as LEDs are much more common now. Or should I just stick with the below recommended higher wattage hallogen bulbs for enhanced lighting?
https://www.xenonpro.com/honda/2006/civic-ex-sedan
Last edited by 06 EX Mild Mods; 01-26-2018 at 09:44 PM. Reason: remove formatting info from pasting some text.
Received 1,149 Likes
Rep Power: 485 Re: LED Bulbs for Headlights 2009 Civic
Watch this video before pulling the trigger on LED bulbs
A lot of LED bulbs have crap light output that scatters light everywhere. If you want something with usable light, find something that replicated light output from a halogen bulb. From that video, the Supernova V3 has great output (+130% brighter than the halogen they comapred) and great beam pattern, but rings in at about $150 at headlightrevolution.com. There's a bulb that they reviewed that came out better, the GTR lighting Gen 3, came out +140% brighter than stock with the best beam pattern. However, carries a pricetag of $200 at headlight revolution.
1 Post
Thanks for the video, like the firearms, too many hobbies, too little income and time! I think I will do this project in stages first replace the badly fadded head light assemblies and OEM option driving lights now with road debris holes in them and fab some sort of protective cover for them to prevent their re-damage. Then save up and install the GTR lighting Gen 3's LEDs.
[insert shameless plug for my gun thread in my signature]
I recently did a review on some LED bulbs I dropped in my fog lights.
Review: Calais COB LED Fog Light Bulbs ★★★★½
Yellow wouldn't be quite suitable for low beams, but they'd work great for high beams
It's worth a look. I've had them on my car for 5 days now, and me being uber ricer like I am, I keep them on when my headlights are on (I love the yellow/white contrast look they give). So far, no issues, but it hasn't been remotely warm out. I'm saving full judgement for when Vegas summer hits, then we'll see if these $23 LED bulbs last. But, yeah, so far, so good.
usajags84
15
08-19-2015 03:12 AM
bahena08
04-11-2015 05:09 PM
