Gauge cluster flickers and turns off!
Old 11-03-2015
Crimson's Avatar
Crimson is an unknown quantity at this point
I have a 2006 Civic EX Coupe
While driving a long distance i noticed the gauges resetting almost every hour. i did not know what it could be, so when i got to where is needed to be. I had the Battery, Alternator, Starter, ELD Relay, and some Fuses. On my terminals I did only replace my negative terminal and left the positive stock.
When I take the positive terminal off and reset the system and put it back on. The dash continually flickers and all of the indicators go on and off for a minute or two, then they will stop and random indicators will stay on. I am not sure what else I should be checking.
Old 11-03-2015
Re: Gauge cluster flickers and turns off!
Can you explain more about what happens and what you see?
Which parts of the dash and gauges are affected?
Make sure the key is turned off before you connect the battery cables.
Adam925
11-19-2019 10:56 AM
jordan1794
06-08-2015 08:37 PM
jbander
06-04-2015 05:56 PM
AlphaInfinity
11-21-2001 03:15 PM
riceburnrex
11-08-2001 10:21 PM
Quick Reply: Gauge cluster flickers and turns off!
