Power door locks not working
Old 08-31-2015
jdrolltide's Avatar
jdrolltide is an unknown quantity at this point
Exclamation Power door locks not working
I've got an 07 Civic LX coupe and the power door locks don't work. I've searched the threads here and none are the same as what I'm experiencing.
Neither door lock switch works inside the car and neither does the remote. I do hear a faint click under the dash when either switch or the remote is used. The lights do flash when you hit unlock on the remote. Nothing happens when you hit lock on the remote.
There is no clicking, etc at the door and there is no movement of the manual lock lever at all.
Any ideas?
Thanks in advance!
Old 08-31-2015
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
Re: Power door locks not working
Not incredibly helpful here, but it's best to check the simple things first...
Have you taken a look at the fuses?
Old 08-31-2015
jdrolltide's Avatar
Yep. Fuses are good.
Old 08-31-2015
Sounds like it's gonna be a MICU problem inside the fusebox, but I'd sure want to do some testing before pulling the trigger on that one.
And, um, if it does get to that point of replacing the fusebox, it'll have to go to a dealer for programming as the MICU is part of the immobilizer system on those cars.
Old 09-01-2015
jdrolltide's Avatar
In my best "Church Lady" voice, well isn't that special! I'm sure that's not cheap.
If it makes any difference, the lights do activate when I press lock on the remote.
Will an MICU problem affect any other functions of the vehicle?
Thanks for the replies!
Last edited by jdrolltide; 09-01-2015 at 07:00 AM. Reason: Add a follow up question.
Old 09-01-2015
MICU is Hondas equivalent of a body control systems computer, and yes there is a lot of stuff that it does.
Will anything else be affected?? I have no idea.
Like I said, I'd want to do some testing to make certain there isn't something else causing the issue before pulling the trigger on that unit.
roverben
01-21-2019 05:16 PM
maaronia
05-14-2015 10:46 PM
MamaBear2015
05-03-2015 02:17 PM
darwin-t
04-18-2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
11-07-2001 11:19 PM
Quick Reply: Power door locks not working
