1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
car turns off in drive or reverse but not in parking or neutral!!
Old 08-03-2009
921.6vtec's Avatar
921.6vtec is an unknown quantity at this point
Cool car turns off in drive or reverse but not in parking or neutral!!
I have a 1992 Honda civic dx with a 1.6 vtec engine i swapped into it, I was having 2 problems the first one was it would loose acceleration and then get it back again while running and the problem was my o2 sensor, that is fixed but now i have another problem i dont know what it can be? any help will be greatly appreciated. This happens not all the time but mostly when the car is warmed up and used for at least 30 min. The car is running good with power but when i get to a red light and just idle in drive the car starts shaking as it tries to stay on but it just dies most of the time and this happens in drive or in reverse, so for this not to happen i have to put the car in parking or in neutral when i stop completely in a red light and the car just stays on without no problem and after it dies it turns back on without a problem every time but its getting me frustrated because i cannot find what is the problem i changed the distributor, iacv, computer and map sensor from a car that has no problem, brand new spark plug cables (even upgraded to some better ones), and spark plugs. Throtle body,fuel injectors, and fuel pump from the junk yard and the problem is still there. sorry for making this so long just trying to give as much info as possible so i can get better help any answers will be helpful
921.6vtec is offline
Old 04-20-2010
zavnet's Avatar
zavnet is an unknown quantity at this point
Re: car turns off in drive or reverse but not in parking or neutral!!
could someone help this dude .. i am having the same problem.... the dat eis 2009 august .. did u find a solution?
zavnet is offline
Old 04-21-2010
921.6vtec's Avatar
Wink Re: car turns off in drive or reverse but not in parking or neutral!!
no i ended up selling the car but then a mechanic told me that it was the brake booster. He said that is a common problem in the honda but i never had the chance to try it but you can go ahead and try it maybe that will fix your problem just let me know what your solution is so i can know.
Old 04-23-2010
zavnet's Avatar
i believe this is the exact problem that i am having and is about to try this ... i will give that a look also
the Torque Converter Clutch (tcc) not dis-engaging when coming to a stop .. yes it could be the brake stop light switch not sending any signal to disengage he clutch....either way the clutch is suppose to disengage when going to like 6kmh.. it doesn't hence stalling the car also .. this was internet research which matches up to the problem that i have.
see the link below best one i have come across
http://www.montecarloss.com/TCC_Solenoid.html
so by the way r u saying that u sold the car with the problem? lol
zavnet is offline
Old 04-23-2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
So did you not think it could be a problem with the transmission when you were changing everything else?
Think of it as a manual transmission and you left your foot off the clutch.. when you stop with the car in gear, the car is going to stall. If you stop with the car in neutral and your foot off the clutch, the car won't stall. If you leave the car in gear and push the clutch it when you stop, the car will not stall.
Something is wrong with the automatic transmission clutch(es).
Awjvail is offline
Old 04-23-2010
oldskool89's Avatar
oldskool89 is an unknown quantity at this point
That's so weird I wouldn't have guessed the booster would be at fault right away.. My first reaction would've been that MAP sensor.. This is really helpful for me also..
There's alotta stuff that u learn from here lol.
oldskool89 is offline
Old 04-28-2010
zavnet's Avatar
PROBLEM FIXED !!!... Well the link above did not help me because i took out the the valve body and replaced it completely and still had the problem . the transmission guy blamed the electrician who wired the car so i went to another electrician who also blamed the transmission ... so my bro and i got upset and got rid of the transmission all together and bought another one and yup it worked. no more problem that trany that i had was total garbage and to think i just bought it to do the swap and ended up having to buy another.
zavnet is offline
Old 10-03-2015
Cotie's Avatar
Cotie is an unknown quantity at this point
I'm having this same problem and I changed the tranni and it still does the same thing
Cotie is offline
The following users liked this post:
BeElegant (06-04-2021)
Old 04-07-2017
Mario Moreno's Avatar
Mario Moreno is an unknown quantity at this point
So what happened? They barley called me to fix some like this on a ford ecoline E150 I'm about to check the transmission torque converter the break light switch and break booster
Mario Moreno is offline
ChristinaVHH
05-10-2015 03:51 PM
Trav_02civic
Engine start problems
04-23-2015 08:57 AM
SSMatey
04-13-2015 06:09 PM
01civicboi
Bolt-on Engine Performance
11-02-2001 07:33 AM
Quick Reply: car turns off in drive or reverse but not in parking or neutral!!
