Go Back   Honda Civic Forum > Honda Civics by Generation > 1st - 5th Gen
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
1st - 5th Gen In the years from 1973 to 1995 Honda released it's 1-5th Generation Civics
LinkBack Thread Tools Search this Thread
Old 01-03-2011   #1 (permalink)
1992civicdx is an unknown quantity at this point
How do you remove the starter Relay from a 1992 Civic DX
Hey! I have a 1992 Honda Civic DX. I removed the starter to change the relay, the starter came out in one peice, but the soleniod assembly is still in the car. I have detached all wires, removed all bolts, and tried to remove it, but it won't budge. I had to walk away, cause I was starting to break the plastic peices around the terminals! It is a Nippendenso type starter.
What am I doing wrong??!!
1992civicdx is offline   Reply With Quote
Old 01-03-2011
CivicForums
Honda Civic
Paid Advertisement
Tags
1992 , 1995 , 92 , assembly , civic , dx , honda , ignition , located , relay , remove , si , started , starter , starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Need Underhood Fuse Box Diagram
Stuck Brake Light Switch
1995 Civic DX rough idle what causes it and how to fix
VIN Numbers: You should know where your civic was quality built!
D15B7 Timing marks question and confusion?
smells like gas inside my car
specs/info for the 1983 Civic 1500 S
My 95 Honda Civic EX Coupe
Engine ground wires
best gas milage setup
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
