eBay fog lights wired right and no lights
Old 04-14-2016
Hutch1051's Avatar
Hutch1051 is an unknown quantity at this point
Exclamation eBay fog lights wired right and no lights
Hi guys I got a set of eBay fog lights from a friend I know they worked on her hatch she pulled everything and gave it to me. So I wired everything in plug and play and no lights. I checked all the harnesses. Everything works from the connector behind the fuse. And the lights worked. The switch works and the relay works. The only thing not working is the fused wire that plugs into constant power in the fuse box. I decided to wire straight from the battery to the fussed wire and nothing. No fuse poped nothing. I just wanna know why my lights aren't working and what I can do to bypass and get my fog lights working. Help me out guys please!
Hutch1051 is offline
Old 04-14-2016
Re: eBay fog lights wired right and no lights
Test light, as low as $3
Understanding why and how to use it, priceless.
ezone is offline
Old 04-24-2016
Dr Krieger of Modification
mac25's Avatar
Lights should be easy.
The basic schematic should run Like this
V+.......ignition switch....+ side of light - side of light.......ground
As long as you have a solid 12v while the ignition is on, a good ground and your lights are running in correct polarity, then everything should work.
mac25 is offline
NathanKeller
02-06-2016 10:55 PM
Bobby Reynolds
02-06-2016 07:50 AM
mrohitredd
01-29-2016 02:49 PM
Niaboc67
01-18-2016 06:25 PM
Handuh
01-17-2016 04:16 PM
Quick Reply: eBay fog lights wired right and no lights
