bad knocking sound when clutch pedal in
Rep Power: 0 bad knocking sound when clutch pedal in
So i was driving down the street.. stopped to get smokes and i hop back in and my car has a horrible knocking noise only when i put pressure on the clutch pedal.... ive torn it all down... inspected my clutch components and cannot see any obvious damage or problems.... when i put it all back together with a new throwout bearing in it and fresh fluid... still knockin like the police.... please for the love of god help me....:/
Re: bad knocking sound when clutch pedal in
See if the knock is coming from the engine instead of the trans
Measure crankshaft end play (checking for thrust bearing wear)
Rep Power: 0 Re: bad knocking sound when clutch pedal in
Ive looked at the rear end of the engine and felt for any looseness or anything obvious but everything seems tight.... lack of a dial indicator leaves me without exact measurements..... it only happens when the clutch has pressure on it.... never when driving,or in neutral or anytime the clutch is engaged... only once the pressure plate has pressure applied to it
Do you have to push the clutch pedal all the way to the floor to make the noise, or will it make noise if you just rest your foot on the pedal without pushing it down enough to disengage the clutch?
That should rule out a pilot bearing noise then.
Seems like you're probably down to something in the throwout mechanism, pressure plate/fingers, or crank thrust. Or something else oddball that wouldn't be typical.
Stethoscope it, figure out if noise comes from trans area or engine area?
Ok... ill have to get a helper... ill give it a shot n see what i can come up with..... hopefully not anything block related..... really dont feel like pullin the engine out.... thanx ezone
Finally got a whole new clutch set with flywheel.... narrowed it down to the clutch case when i got a real good listen in... so today its out with the old and in with the new! Wish me luck! I sure do hope this fixes my ailments
Supramk3
05-08-2015 11:16 AM
02EXCoupeGuy
12-19-2001 09:47 PM
