Throttle body?
Received 1,149 Likes
Rep Power: 485 Re: Throttle body?
edit: should note that this is not my car and I shamelessly stole this image from a google image search.
Received 1,444 Likes
Rep Power: 338 Re: Throttle body?
throttle body cleaner, available at any car part store...
Re: Throttle body?
No. Clean it in place on the engine. Only need to remove the rubber tube from it for access.
I use carb and throttle cleaner and a toothbrush or nylon bottle brush.
The important part is to get the area between the housing and the throttle blade (butterfly) clean so the blade doesn't stick closed.
Final wipe down with a shop towel.
Wedge a stick on the gas pedal to keep it on the floor and keep the throttle blade wide open, this makes it easier to clean and use both hands.
Bruce2
09-27-2015 08:45 PM
Bricoleur
09-09-2015 12:30 PM
