Go Back   Honda Civic Forum > Honda Civics by Generation > 6th Gen
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
6th Gen In the years from 1996 to 2000 Honda released it's 6th Generation Civic. Chassis codes: EK9, EK4, EK3, EJ6, EJ8, EJ9, EM1
LinkBack Thread Tools Search this Thread
Old 07-06-2011   #1 (permalink)
Points: 1,684, Level: 23
Points: 1,684, Level: 23 Points: 1,684, Level: 23 Points: 1,684, Level: 23
Level up: 84%, 16 Points needed
Level up: 84% Level up: 84% Level up: 84%
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
97 Civic coupe is an unknown quantity at this point
Shifter stuck
So this isn't a new problem but it is getting increasingly annoying. I have an automatic and when I shift from Park to Reverse or vice versa, it is really difficult. There is a lot of resistance between those two gears. Every other one is fine. Any was to fix it? Or is this an expensive transmission issue?
97 Civic coupe is offline   Reply With Quote
Old 07-19-2011   #2 (permalink)
Points: 4,241, Level: 41
Points: 4,241, Level: 41 Points: 4,241, Level: 41 Points: 4,241, Level: 41
Level up: 46%, 109 Points needed
Level up: 46% Level up: 46% Level up: 46%
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
marek91 is an unknown quantity at this point
Re: Shifter stuck
i had the same problem when i first got my sedan, i put some lucas tranny fluid in it and continued driving it and it eventually went away
__________________
Quote:
Originally Posted by 530matt View Post
i hope your f&cking kidding,
if you really have a b16 under the hood of your car
and you plan on bolting on a $19.99 "Electric supercharger"
somebody should look you square in the face,
take six steps back, get a running start, and rack you in the sack with a steel toe boot as hard as they can,
marek91 is offline   Reply With Quote
Old 07-19-2011
CivicForums
Honda Civic
Paid Advertisement
Tags
03 , 2000 , 2006 , 97 , 98 , automatic , civic , gear , honda , locked , shifet , shift , shifter , sticking , sticks , stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
$500 to replace o2 sensor???
fluctuating idle problem
Shifting problem, won't go into gear
Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
96-00 ex rear disc conversion?
Tire Size
Power Window issues on my 96 EX
1998 Honda Civic Automatic Transmission slippage
97 Civic RPM Fluctuation when Driving
My new 4th gen hatch
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
