Sponsored by:
Sponsored by: DashLynx
will manual ecu work in auto car
Old 02-08-2016
greg2934's Avatar
greg2934 is an unknown quantity at this point
hi i have a 04 civic Canadian si 1.7 vtec auto... was wondering if a ecu from a standard would work in my car... ecu is fried, and found a new one in a standard car just not sure if it will work...
greg2934 is offline
Old 02-08-2016
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: will manual ecu work in auto car
Signed on to find out. What fries a ECU? What is the normal life of them when all goes well. Know some of the older ones had relays in them that would wear out?
RIPSAW is offline
Old 02-08-2016
greg2934's Avatar
the biggest thing with those year civic, the alternator will take out the ecu witch is what happen to me i think... the top bracket of the alt acts as a ground, so if the bolt is lose, or if there is dirt, and corrosion, it will short out, and take out you ecu.... from what i understand anyways
greg2934 is offline
Old 02-08-2016
No it will not work. An ECU from a manual trans car cannot operate the automatic trans.
You need a PCM from an identical car to yours, and of course programming the immobilizer before the engine will run.
Find and fix the root cause of your PCM failure before you ruin a new one!
ECM=Engine Control Module
PCM=Powertrain Control Module (engine+trans)
ezone is offline
Old 02-08-2016
greg2934's Avatar
thanks for the info
greg2934 is offline
Old 02-11-2016
greg2934's Avatar
does it matter what year ecu 01 to 05
greg2934 is offline
Old 02-11-2016
RIPSAW's Avatar
If you go here,http://www.collegehillshondaparts.co...?part_name=ecu it does not list you Canadian car but it says on a USA car that certain 2004 and 2005 are the same. This one and 4 others interchange. Go to your dealer if you do not have a Canada fish site. Take your part number and ask them if their fish lists the years suitable and their part numbers.
That's a $500 part from Honda and appears to be a rebuild.
RIPSAW is offline
Old 02-11-2016
^ even though they show a core charge, a reman unit would have "RM" at the end of the part number.
GOOGLE....Torontohondaparts
ezone is offline
robjcivic
03-12-2017 12:10 PM
kevfarr
09-18-2015 02:28 PM
injencivic
11-09-2007 02:31 PM
Markias
Detailing
11-04-2001 05:15 PM
energy
11-01-2001 08:25 PM
Quick Reply: will manual ecu work in auto car
